11-13-2012, 08:06 PM | #1 |
Pictures of a BBC installed needed
Looking to see what type of clearance I would have for headers in the future.
11-13-2012, 08:21 PM | #2 |
Re: Pictures of a BBC installed needed
Im in the same boat. Im still trying to shoehorn my bbc into my 65. Others have said headers for a chevelle. I have headers from my 88 cclwb dually im attempting to use. Have to make my own engine mounts to have clearance.. still trying to find a radiator.
Posted via Mobile Device |
11-13-2012, 08:27 PM | #3 |
Put the radiator in the rear and remove the inner fenders. Just a thought. My 37 I puit the radiator in the rear and works great.
11-13-2012, 09:03 PM | #4 |
A good friend of mine put a big block in his 65 Here is a link to his web albums with some pics of what your looking for. Hope this helps!
http://picasaweb.google.com/fritz199090 He moved the motor mounts to the front to give room for his HEI. |
11-13-2012, 09:35 PM | #5 |
The BBC fit great I had to adjust the firewall just a little . I used Sanderson headers no problems.
11-14-2012, 12:48 AM | #6 |
402 with stock big block truck manifolds, in a 64 C10, with big block motor mount perches from a 71. It moved the whole powertrain assembly about 3" forward in the frame. The perches and the engine bolted right in. I did have to shave the upper flange of the frame rail, similar to the 71 with a big block.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! Last edited by argonaut; 11-14-2012 at 12:55 AM. |
11-14-2012, 01:15 AM | #7 |
Thanks!
I am new to this site & have been really impressed with the information here & the sharing that goes on. |
11-14-2012, 01:57 AM | #8 |
60-66 Nut
What I have done is trimmed the top flange of the frame, using a '73-'87 frame as a template. Then you can use headers for a '68-'72, or '73-'87, or the Chevelle headers. Either way, you will not be able to use a mechanical clutch linkage, if you want to run a manual trans. You will be better off converting to a hydraulic clutch in that instance. If you choose the Chevelle headers, I believe the bellhousing crossmember has to come out.
11-14-2012, 02:20 AM | #9 | |
H'mm I am going to run a 4 speed, so I am going to have to fab up something there. I am planning to use a 73 & newer frame so hopefully that will make a difference. |
11-14-2012, 06:42 PM | #10 |
http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Lots of pictures
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
