Old 11-13-2012, 09:35 PM   #1
c10 custom
ac compressor issue
hi guys 1994 chev truck the ac compressor keeps cycling on and off every like 2 seconds any ideas would be great thank you
c10 custom is offline   Reply With Quote
Old 11-14-2012, 09:43 AM   #2
ChevyTech
Re: ac compressor issue
Low on refrigerant.
Old 11-14-2012, 10:36 AM   #3
JWall
Frequent Flyer
JWall's Avatar
Originally Posted by ChevyTech View Post
Low on refrigerant.
Yup. What he said.
- Justin
1 Owner 1976 SWB
Old 11-15-2012, 08:43 AM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Is it cycling when you have the controls selected to something other than the A/C? If so, then your control box in the cab may be messed up and it is stuck in the defrost mode, where hte A/C is supposed to cycle intermittently, to keep condensation down in the cab. Other than that if you have A/C selected and it is short-cycling, then once again LOW on freon.
Unplug the wire on the side of the accumulator pressure switch and put a jumper in it, if the compressor runs constantly, then you will need to look at the freon charge.
Frank
piecesparts is offline   Reply With Quote
Old 11-16-2012, 03:13 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If you have it set to defrost, it will cycle on and off. But, all my experience is on my '96. But low refrigerant will definately make it cycle. It's designed to do that.
Member Nr. 2770
Old 11-17-2012, 07:22 PM   #6
95haganml
My 95 5.7 700R Silverado has issues with the low pressure switch flaking out and causing rapid A/C clutch cycling. After checking the refrigerant pressures and finding they are okay try replacing the A/C low pressure switch.
95haganml is offline   Reply With Quote
