Old 11-14-2012, 12:32 AM   #1
71chevystep4x4
71chevystep4x4's Avatar
first start up? on junkyard engine
Im about to start my 5.3 for the first time in god knows how long. I have a mechanic friend that tells me to squirt a few squirts of oil into each cylinder before I fire it off. What are all of you LS swappers doing for first time starts with in your engines that have been sitting for a long time between running? And what kind of antifreeze are you running? The red stuff that they come with now days, or the conventional green stuff?
71chevystep4x4 is offline   Reply With Quote
Old 11-14-2012, 01:47 AM   #2
ls1nova71
ls1nova71's Avatar
Re: first start up? on junkyard engine
I usually pull the plugs and the injector fuses and crank it over for about 10 seconds at a time until you get oil pressure. A little oil down the cylinders wouldn't be a bad idea, it will help the rings since the cylinder walls are probably dry. As for antifreeze, flush out any remaining Dexcool with water and refill with green. Dexcool is horrible!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-14-2012, 06:41 AM   #3
eagleuh1
eagleuh1's Avatar
I squirted some marvel mystery oil in my plug holes,set overnight, left plugs out and pulled fuses like LS1Nova71 did for injectors and coils. It doesn't take long for oil pressure to come up. I put a temp guage on just to be sure I had good pressure too. Then put everything back in and stand back for majic. Why is Dexcool horrible? I've been using it no problems so far.
eagleuh1 is offline   Reply With Quote
Old 11-14-2012, 12:31 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I threw a little wd40 in each cylinder when it was sitting on the stand, a few months later, it was in the truck and fired first crank.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-14-2012, 02:22 PM   #5
Wasted Income
Boosted Member
Wasted Income's Avatar
I'm with these guys. I normally pull the fuel pump fuse, and disconnect the coils at the valvecover junctions and crank it for a bit to get some oil moving, then fire it up.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 11-14-2012, 10:29 PM   #6
71chevystep4x4
Thanks, I figured priming it would be best, just not used to not having a distributer to do it with. Funny about the Mervell Mistery oil, I've heard that option as well, some guys swear by that stuff!!
Old 11-16-2012, 11:59 AM   #7
Custom 68
Custom 68's Avatar
One thing to think about if it does not start immediatly is your injectors. Mine were stock ones that sat for quite a while they were gummed up and did not squirt fuel. I pulled my fuel rail and with a helper I unhooked the coil wiring and did one injector at a time. I hooked up the one to work with and started cranking over while tapping on the injector till it shot fuel onto my rag. I went to the next and so on. Then it worked great.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
