Old 11-14-2012, 01:55 AM   #1
wraprail
wraprail's Avatar
Flip kit axle location
[IMG][/IMG]So when you install a flip kit (85C10) it moves the axle housing forward ? How much? I'm doing my own flip (the right way) and can't remember how much it moves to center the rear wheel in wheelwell I assume.
Anyone know?
wraprail is offline   Reply With Quote
Old 11-14-2012, 02:28 AM   #2
cory d
cory d's Avatar
Re: Flip kit axle location
it needs to go back so you dont bottom out the yoke on your trans/driveshaft. 1/2-1" should be good
cory d is offline   Reply With Quote
Old 11-14-2012, 02:59 AM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
About 1 inch will do you
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-14-2012, 03:32 AM   #4
wraprail
wraprail's Avatar
So when you move the housing on top of the springs it actually moves forward an inch? And the offset on a "flip kit" moves the housing toward the rear so the driveshaft doesn't bottom out.
My last truck i installed the housing centered on the spring pins but had to have a driveshaft made cuz it was a 9 inch ford but it awalys looked like the rear wheels were not centered in the wheelwell ( they were too far back) but you are saying they move to front.
Interesting.
Old 11-14-2012, 04:56 AM   #5
cory d
cory d's Avatar
it needs to move back because the the drive shaft will be flatter. im too tired think straight. kinda like how lifted truck can need a longer shaft
Old 11-14-2012, 07:51 AM   #6
wraprail
wraprail's Avatar
Ok makes perfect sence now I wasn't thinking about the driveshaft arc. So will moving it back (the rearend housing) an inch make it still centered in the wheel opening?
Old 11-14-2012, 08:11 AM   #7
jjzepplin
jjzepplin's Avatar
Subscribed.. I am doing it this way too.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-14-2012, 08:36 AM   #8
wraprail
wraprail's Avatar
Heres what I got. Drilled the offset holes in the wrong end though (move axle forward) lower plate is shock mount
Old 11-14-2012, 10:30 AM   #9
J Knight
J Knight's Avatar
Just to be clear, when you weld those perches to your axle tubes, put the offset hole forward so when the rear end is mounted the axle will move toward the back.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 11-14-2012, 10:36 AM   #10
wraprail
wraprail's Avatar
Got ya. I may just mount them centered and shorten the driveshaft if the wheel isn't centered in wheelwell.
Old 11-14-2012, 11:09 AM   #11
slam59
Subscribed as well. Seems a better way to lower the rear I think. Best to make own perches or any paticular set or brand better than others?
1974 C10 swb 350
1977 3/4 ton Silverado 454
1999 2 door 2wd Tahoe
slam59 is offline   Reply With Quote
Old 11-14-2012, 02:15 PM   #12
wraprail
wraprail's Avatar
These came from 4 WheelParts. Warrior was the brand $24.95 O
Lower mounts are from Speedway Motors
Old 11-14-2012, 09:33 PM   #13
lilpoindexter
lilpoindexter's Avatar
Yes man, the flip kits move your axle backwards, so it looks stupid because it's not centered in the wheel opening. i hated the way mine looked, which made me swap trannies sooner rather than later since I was going to need a new driveshaft anyway...I redrilled my flip brackets to move the axle in the center of the wheel opening, it looks, much, much better like that.
lilpoindexter is offline   Reply With Quote
Old 11-14-2012, 09:47 PM   #14
INSIDIOUS '86
Mine centered just fine. But it's a fleetside
I got the axle perches from summit and they came in a mopar box. About $20 I think. Very thick ones and full formed like the factory ones
Old 11-14-2012, 11:03 PM   #15
wraprail
wraprail's Avatar
i
I kinda thought it did.. Im glad you confirmed this.
E
Yours centered when you used the CENTER hole on the spring perches?
Hmmm.. wonder how?
Old 11-14-2012, 11:05 PM   #16
INSIDIOUS '86
i
E
Hmmm.. wonder how?
No drilled mine so it's an inch back
Old 11-15-2012, 01:46 PM   #17
slam59
What all exactly do you have to buy parts wise to do a drop in the rear using this method of lowering? How much about does it cost? Need new shocks in the rear afterwards?
1974 C10 swb 350
Old 11-15-2012, 09:17 PM   #18
wraprail
wraprail's Avatar
Oh ok you moved the housing back an inch and its centered in the wheelwell?
I wonder what your wheelbase Measures now? Im gona do mine tonight or tomorrow and still am undecided if I will move mine back or not. The wwheel is centered now before the flip
All you need is leaf spring pads and you need to do something with the shocks. You can use shock extenders in the stock location or in my case I am doing a weld in step notch and relocating the spring hangers so I will move the shocks and make new mounts. .
Old 11-15-2012, 09:56 PM   #19
INSIDIOUS '86
Not sure what my wheelbase measures. The front A arms is an inch forward and so is the rear. Still handles like a fat corvette
Old 11-15-2012, 10:07 PM   #20
legendman
legendman's Avatar
Stock wheelbase is 117.5 inches, interested to know what it is on your trucks with a flip kit installed.
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 11-15-2012, 10:20 PM   #21
J Knight
J Knight's Avatar
Mine measures 117.25 with a flip kit.
John
Old 11-15-2012, 10:24 PM   #22
cory d
cory d's Avatar
anyone know what color this is?
Old 11-15-2012, 10:30 PM   #23
MotorHead Lon
MotorHead Lon's Avatar
I have the weld on axle perches as well. I havent drilled mine, and my wheel base is 116".
MotorHead Lon is offline   Reply With Quote
Old 11-19-2012, 11:10 PM   #24
wraprail
wraprail's Avatar
You need the spring pads/perches ($12.99 pair) and lower spring plates/shock mounts ($28.99 each) both from speedway motors.
If you don't change anything else (stock springs and hangers) then you can use stock shocks.
I modified the springs and had to use shorter shocks.
Did you need to shorten driveline?
Old 11-19-2012, 11:28 PM   #25
wraprail
wraprail's Avatar
So got this finished up kinda. Heres some pics,
Spring pad and lower plate. Factory U-Bolts
Shorter shock, upper mount was cut off rear end housing and reused.
I know the welds look awful! lol
Relocated brake hose
Driveline was too long as expected (i mounted the rear end housing centered on the pins) i just happened to have a shaft laying around that fit perfectly! I think it was out of a mid 80s G body
The end result is a centered wheel and roughly same cost as a flip "kit" only much stronger.
