![]() Join Date: Apr 2008
Cab mount cushion question
Hey all,
Im starting to install the Prothane poly cab mounts (1/2 ton truck) and have run into a question. I noticed that of the 4 main cushions that 2 are slightly shorter/longer than the other 2. This discrepancy is only 1/8" and looking at the cast-in numbers they do seem to be different parts. My only problem is Ive never seen a good stock set to know which position (front/rear) takes the appropriate height mount. I searched & couldnt find anything regarding this situation. Can anyone shed some light on this? Thanks in advance, Shane |
Re: Cab mount cushion question
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
Exactly the info I was searching.
Many thanks! |
