Glove box question
Maybe a silly question but I was wondering, is there a spring or something that 'pushes' the glove box door open after you hit the latch button?
The button on my 66 unlatches fine but I have to dig my finger into the side to open the door. If I adjust the latch to make it easier to open the door, it rattles when closed. Just curious...
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
Re: Glove box question
There are two little rubber bumpers that give it a little "spring"....also keeps the glovebox door from ratteling. I replaced my dry rotted ones and the door opens easier. There is no spring assembly that helps open it though. The lock kinda acts like a spring to open it. You might check the condition of the rubber bumpers...they are still produced and maybe adjust the latch a little.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
^^ thank you sir!
1963-C10 is 100% correct! Also if you install the Glove box Light it too has a spring loaded switch that also pushes the door open!
People who make excuses didn't want to do it in the first place! ![]() http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16 |
Yes....and they are easy to install. Just plug & play
Yes. There is a small spring located on the bottom center of the glovebox door. It just snaps into place. 66C10.
Was that for 60-66 or just 64-66. I have never seen a spring in a 60-63 glove box door. Im not saying there isn't one, I've just never seen one and Ive taken a few out/apart.
tell me more about this spring? any pictures?
64-66 use a small spring at the bottom center, it catches the bottom lip of the dash.
I did not take any pic's when I installed.... I'll look at my LMC cat.... It's just a small piece of spring steel that has a curve to it. It just snap into the glove box door....
UCA63
The 60-63 chevies had a raised pivot point.
push button and push lower part of door T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
Who Me?
I push the button with one finger and my thumb is pushing on the bottom of the door.. That seams to work too! my little bumpers have no spring left in them.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#13 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
The '60-'63's also had the little flat spring on the lower edge of the glove box door.
#14 |
The lower center spring looks like a clip, not like a traditional " spring ", I had forgotten about that even being there.
#15 |
Ahh...ok, now that Ive seen. Never really thought of it being a spring.
#16 |
I replaced the little rubber bumpers and it didn't help with mine. I think I need one of them there springy things.
66 shorty ![]() |
#17 |
Moderator
![]() ![]() Join Date: Aug 2011
There are a set of bumpers at the lower hinges also. The door sits against them when open.
#18 |
#19 |
Moderator
So anyone have a picture of the spring?
edit - Oh, GMC...
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 12-31-2018 at 07:13 PM. |
