11-14-2012, 02:29 PM | #1 |
Brake/ proportion valve question
I have searched and can't really find a answer
I have a 66 c-10 with stock brakes. I replaced the stock crossmember with a sectioned one and messed up some brakes lines so decided just to up grade to the 67 dual chamber master cylinder. I want to run all the lines since I have the motor out. My question is I know right now I do not need a proportion valve but down the road I want to install drop spindles with disk non power brakes and I will need a valve. I would like to just install a valve now since I have room to work in there with motor out. Questions I have now are is it safe to run the valve with drum/drum brakes and if so witch one I need? Posted via Mobile Device
1966 C-10 long wide- currently with 2 3/4 sectioned crossmember, 3 inch cupped a arms with 2700 bags, 67 master cylinder, in the middle of a v8 swap, soon custom rear wishbone set up and bags 1942 chevy/divco ambulance 1937 chevy truck |
11-14-2012, 04:26 PM | #2 |
Re: Brake/ proportion valve question
I dont know if its safe, but its not needed until you put disk brakes on the front. I have seen distribution blocks on drum/drum, but I dont know that Ive ever seen a proportioning valve on a drum/drum truck. They are not that hard to install...I would hold off until you hav edone the front end conversion.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
11-14-2012, 05:00 PM | #3 |
my theory was just that i see them mounted on the frame and dont want to have to cut my brake lines and redo the fittings and re flare ends when i can just do it all right now tieh the engine bay clear
11-14-2012, 05:13 PM | #4 |
well seems i have answered my own answer doing further research i was thinking a dist box not a portion box.
11-14-2012, 07:50 PM | #5 |
You could intall a proportioning valve and leave it all the way open...
Project Change of Plans: http://67-72chevytrucks.com/vboard/s...d.php?t=513135 '62 C10 SWB '03 Express Van 5.3l Dead (parting out and using motor) '99 Silverado 4.8l 5 speed 4wd |
11-14-2012, 08:12 PM | #6 |
do not install a prop valve or distr block with a stock 67 dual res master cyl that you've used to upgrade you 66 with. That master cylinder has built in proportioning for a drum/drum system. It's a great swap but prop valve not to be used for just that swap. Once you go disk/drum or disk/disk - a prop valve will be necessary.
here's a thread with some more details: http://67-72chevytrucks.com/vboard/s...d.php?t=332148 (chief rocka's great thread) and http://67-72chevytrucks.com/vboard/s...d.php?t=487384 (i did exactlywhat you did in my old 66, here's the thread) |
11-15-2012, 02:23 AM | #7 |
So when I do change to disk I will need to change the mc to a disk/drum and a proportion valve or just a valve
11-16-2012, 12:12 AM | #8 |
60-66 Nut
You will need to change to a disc/drum master cylinder and add a disc/drum proportioning valve.
