11-14-2012, 05:33 PM | #1 |
NV4500/NP205 question (s)
Finally located a correct GM nv4500 (94). Guys selling me everything (bellhousing, etc). 78K original miles.
I'm told that round hunk of steel on the output is a harmonic damper used with the OEM dual mass flywheel, but it's tuned to the OEM engine and it can be taken off and tossed along with the DM flywheel. Anybody have any insight on this? Dirty Larry? By sheer luck, after some conversation, I discovered he also had a 32 long spline input NP205, 6 bolt round pattern, that I was able to buy off him (for a price!). I think I need an adapter (listed/shown on the AA site) but otherwise it will mate right up. Again anybody have any input? And yes, I'll be using the AA bellhousing (not the OEM shown), and slave bracket. Thanks, Mike Last edited by SunSoaked; 11-20-2012 at 09:30 PM. Reason: Clutch wasn't included-my bad |
11-14-2012, 06:33 PM | #2 | |
Re: NV4500/NP205 question (s)
Just a question, but...why the change to the AA bell/slave bracket over OEM? |
11-14-2012, 06:41 PM | #3 | |
I assume I will have clearance issues with a P/S throwout bearing arm with a P/S front driveshaft? The AA is a D/S. |
11-14-2012, 06:59 PM | #4 |
Possible, though my buddy ran the OEM bellhousing/slave with pass. side driveline and throwout arm with no problem. But I'll agree that moving it to the drivers side (like the earlier generation of hydraulic bellhousing) is a good idea.
11-14-2012, 07:04 PM | #5 |
Also, pardon my envy. I have been wanting to do this swap, but can't justify it as my SM465/NP205 have about 3k miles on rebuild.
11-14-2012, 07:15 PM | #6 |
Windy Corner of a Dirty Street
That is a nice score on the trans and tcase! That is the NV4500 I originally wanted as it is an earlybird with the 6:54 gear ratio (like an old SM465) rather than the 5:61 ratio.
I believe that damper is more indicative of a diesel like they said but shouldn’t matter if use behind a gas I wouldn’t think. If you are worried about the damper you could remove it and replace it with the spacer that goes in it’s place. Be warned, that nut on the tail shaft is a mo-fo to get on and off! If it were mine, I would run it the way it is…damper and all. Maybe someone else can chime in on that.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
11-14-2012, 07:23 PM | #7 |
Actually, looking thru Larrys build thread specifically this post #113 (Credit to Larry), it appears there is plenty of clearance on the P/S. If thats the case, then I think I can use the 94 Bellhousing and just have to have a hose crossover from the D/S M/C?
I'd prefer to use the OEM and not spend $368 on an AA part I don't really need. The important thing is avoiding the internal slave. I hear ya. For me, I'm starting from scratch, so I commited myself to getting what I wanted the first time around and not wishing I had done it another way after the fact. It's taken alot of searching, a good amount of cash (although I have gotten some sweet deals) and a big dose of good luck! |
11-14-2012, 07:53 PM | #8 | |
I plan on eventually adding the Ranger OD unit to mine to gain overdrive! Last edited by Redcap; 11-14-2012 at 08:00 PM. |
11-16-2012, 10:38 AM | #9 |
I have my t-case bolted directly to the trans w/out adapter using the 32 spine input gear as you have. You will need to watch for contact between the tailshaft lip and t-case shift rods. Some clearancing maybe needed.
As for the balancer, Larry's right, it's necessary for DM fly wheels usually used in diesel applications. Without the balancer the trans vibrates enough and destroys the mainshaft. Seen it happen twice now in my buddies '94 6.5L. I have been warned that the balancer should not be used with single piece flywheels but i have a couple acquaintances that are doing this without failure as of yet. So i'm not 100% positive on what to/not to do in this situation. congrats on your set up. -steve Larry, so after some use, you have found you would have preferred the lower 6.54 gearing over the taller? Assuming for the trail?
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
11-16-2012, 12:55 PM | #10 | |
GM 92-94 First Gear 6.34 Second Gear 3.44 Third Gear 1.71 Fourth Gear 1.00 Fifth Gear 0.73 Reverse 6.34 95/up GM First Gear 5.61 Second Gear 3.04 Third Gear 1.67 Fourth Gear 1.00 Fifth Gear 0.73 Reverse 5.61
11-16-2012, 03:13 PM | #11 | |
I know for a fact this trans (balancer) came from the factory behind a gas engine. My brief internet research tells me the balancer/Dual Mass Flywheel are a "tuned" system based on the engine. I read theres a link between internal/external balanced engines. I need to do more research and see what the real deal is before running without it. Is your 205 the "long input"? I'm wondering why AA sells an adapter specifically for the 4500/205 round pattern? I was thinking the adapter was needed with the long but not the short? If its only for the long it looks like it has notches to account for the shift rails. Product# 50-6910 5/5 (1 Review) Description Advance Adapter This spacer adapter is 1.625" in length and is used when retro fitting a GM NV4500 4wd 5 speed transmission to the 1985-91 GM NP205 with a long input gear. This input gear measures 3.50". Steve-What bellhousing are you using? Any clearance issues with it (P/S Bearing fork) if indeed its a 93-94 OEM. Thanks |
11-16-2012, 06:44 PM | #12 | |
Im using the short input so my t-case is bolted directly to the tail of the trans, no adapter or spacer used. The bellhousing is an AA unit for mechanical clutch. I got the whole assembly as a package deal from GearTechHD out on the east coast back in ... ... 2004 ish? The itemized list showed the AA bellhousing priced at $200. Not a bad price compared to them these days but then I also stayed with the mechanical linkage.
11-16-2012, 09:19 PM | #13 |
i have the AA B/H a 94 NV4500 the AA spacer and an 89 round pattern 205. i used a 86 K30 hydraulic clutch set up and the AA bracket to mount the slave. if i was doing it again, i would do it the same. the stock T/O arm location is in a good place to get whacked with the driveline. that could cause more damage at a really bad time than i would prefer to deal with. this is all in my old full size jeep hooked to a tbi 454. i love the combo, but i almost never use the 1st gear. i had a 5.61 nv4500 in the orange truck in my avatar and i think i preferred it. the later ones are synchro'ed in all gears and its nice to be able to go a little faster in reverse.
Ryan |
11-18-2012, 11:01 AM | #14 | |
Posted via Mobile Device |
11-18-2012, 11:34 AM | #15 | |
Also, I'm not sure which direction to go as far as hydraulic clutch bellhousing, or stay with manual linkage with my truck. The truck is 99.9% street driven, and used as a tow rig for an enclosed car trailer part time. |
11-20-2012, 10:58 AM | #16 |
Well guys-Looks like I got good news and bad news.
Bad news: The guy I was dealing with in PA doesn't give me a "warm fuzzy" as my wife would say, so I'm backing out of the deal since I havent heard from him in a while Good news: I located a guy selling a complete conversion package in Id that is still in the truck. The 4500 was just rebuilt less than 200 miles ago before he totaled the truck (rolled it). Hes got all the receipts. Its a 93, and comes with a brand new flywheel, clutch and the pedal assembly, M/C, shifter, etc. The great news is he lives 20 miles from my brother whos a big rig mechanic, so it will be a confident upfront deal. They are going to remove it this weekend. I'm actually much happier with this deal because its virtually all new and I didn't even factor in the price of a new clutch before. I also opened a gold mine of parts availability. Being farming country, there are trucks being parted out everywhere. I'm confidant I'll find that round pattern 205 yet. Got the package for $1000. |
11-20-2012, 11:22 AM | #17 | |
Good luck on the round NP205. I've been looking for that transfercase for a friend and they seem to be selling for $400-500 locally...when you can find one. |
11-20-2012, 02:24 PM | #18 | |
I agree, with Redcap, good luck in finding that round 205 thus the reason my truck ended up with a 27 spline figure 8 205 behind the NV4500. I couldn’t find a round 205 and when I did, I refuse to pay what people thought they were worth. I am a tight whad about that kind of stuff which is why it took me 16 years to get a D60 that didn't leave me feeling like rape victim after doing the deal.
11-20-2012, 09:05 PM | #19 |
i went around in circles looking for the roundy 205 too. i bought one in maine and shipped it here and then bought one locally (attached to the 86 K30 i found for 1300$) maybe a week or two later. now i have a secret one in hiding!
Ryan |
11-20-2012, 09:14 PM | #20 |
Ryan |
11-20-2012, 09:27 PM | #21 | |
I did say "buy off of him" regarding the t-case. My bad, should have said "agreed to sell". He is still willing to sell me the round 205 for $400. I would pay that but I'm a little cautious about the deal since he's on the east coast and I'm on the west. At least with the new score on the 4500, I have family that can check it out and pick it up for me. Plus its freshly rebuilt and comes with a new clutch/flywheel. Thats got to be worth a few $ huh? I have already "LOCATED" another round 205 in that area. It helps to have someone there who knows the locals. Last edited by SunSoaked; 11-20-2012 at 09:36 PM. |
11-20-2012, 09:33 PM | #22 |
If you find one locally for $400 let me know. I'll take it. I'm only building my "dream" truck once.
11-20-2012, 09:35 PM | #23 |
It's not a secret anymore. Does that imply you want to sell it ?
11-20-2012, 10:15 PM | #24 |
11-20-2012, 10:28 PM | #25 | |
ryan |
