Electric Heater Core Valve available?
The Vaccuum operated Valve on the pass fenderwell that lets hot water thru the Heater core,,is there an electric one available? Thanks.
Re: Electric Heater Core Valve available?
I am talking about the Vac operated valve that opens and lets the Hot water into the heater core,,I want to change from vac operated to electric operated valve?
Old member
Yes they are out there.
![]() ![]() http://www.alibaba.com/showroom/12v-dc-water-valve.html http://www.alibaba.com/product-gs/62...ally_Open.html
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Quit if it's not FUN!!!
Most of the aftermarket A/C companies sell a 12V servo hot water valve. Is that what you're looking for?
. http://www.vintageair.com/2012catalo...Page%2074).pdf . Upper right hand corner
MY MOTTO: Eat it all up, Wear it out, Use the last few drops, Spend all you've got, Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life ! . Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee) ![]() |
Yes! thank you! From the looks of it buying the entire Vintageair kit is the way to go for A/C-Heat!
