11-15-2012, 01:25 AM | #1 |
16.5 tires...
Can anyone tell me what size a 9.50/16.5 is in inches? I tried looking but couldn't find out. Also, if anyone is running 16.5 in rims on a 2wd 3/4, what size tires are you running? thanks
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
11-15-2012, 01:40 AM | #2 |
Re: 16.5 tires...
Not sure what dimension you are looking for in your question, what you stated is the actual tire size as printed on the tire itself - but, Firestone makes the tire for that wheel - tire model is Transforce (available in HT or AT - AT is a bit more for off-road):
Shown in the close-up and on a truck with the exact same wheel tire combo (all are HT versions). |
11-15-2012, 01:56 AM | #3 |
Re: 16.5 tires...
Here's a little more detail that may help:
section width = 9.50" diameter = 30.6" Rim width range = 6.75"-8.25" Tread width = 7.3" Revs/mile = 682 Max load = 3195 lbs Tire weight = 40 lbs Max psi = 80 psi All available from this site: http://www.tirerack.com/tires/tires....5THT&tab=Specs Transforce 9.5R16.5 is filtered tot he top. Hope thqt helps. |
11-15-2012, 02:42 AM | #4 |
Re: 16.5 tires...
I just picked up a 69 C20 2wd. It currently has 9.5 x 16.5 in front and 33" x 12.5" on 16.5 in the back. There isn't much selection for 16.5" wheels (except in the 4x4 lifted community). The wheels on my truck are wide (10" I think) ...so I am thinking of putting 33x12.5 all the way around. I think it will clear all the suspension and fenders in the front.
11-15-2012, 10:18 AM | #5 |
Re: 16.5 tires...
Jojaboy, lmk if those 33s fit. I have a set of slots i really want to put on my 3/4 ton 2wd but there isnt a whole lot of selection for a set of tires that will fit the width and not be 33+ inches tall.
11-15-2012, 11:39 AM | #6 |
Re: 16.5 tires...
I was told by a friend that they would fit with no rubbing. True test is to do it and see. As dumb as it may look I think I'm going to move the back to the front and front to the back and see how the 33's clear. (won't leave it that way....just to check fitment)
I also plan to get some shackles and drop the back end down a couple inches just to take the rack out of the stance. I don't want to change the suspension ride but would like to level it out. 33's should clear back even with leveling shackles. |
11-15-2012, 09:22 PM | #7 | ||
Re: 16.5 tires...
