Old 11-15-2012, 02:42 AM   #1
SHANE 73Z
WTB - Small interior/dash/underdash parts
Hey guys,
Looking for the following parts:
1. Under column bracket 69-72 - this is the bracket that holds the pedal stops & bolts in after column with 4 bolts - replacing e-brake 67-68 style
2. SBC upper clutch rod
3. dash bezel 69-72 idiot light - this should have the 3 main holes & switch holes in upper corners - prefer it without cracks, color and or fading not important
4. radio delete plate & hardware
5. switch bezels - i am looking for the style that has the slots on the outer ring - need 2
6. HD cooling lower radiator retainers - need a pair
Let me know what you have. I can pay by Paypal or USPS money order.
Thanks in advance,
Shane
SHANE 73Z is offline   Reply With Quote
Old 11-15-2012, 02:58 AM   #2
PT'S 70 CST
"GO DAWGS"
PT'S 70 CST's Avatar
Re: WTB - Small interior/dash/underdash parts
I should have the three hole bezel, the switch bezels and possibly the column bracket.
I will try and look tomorrow.
PT
70 CST SWB
70 NOVA
93 Indy 500 Pace Truck (SOLD)
94 SILVERADO SWB 5/7 drop
2000 Silverado swb
2005 Nissan Altima 3.5 (Surprisingly very fast)
2004 GMC Yukon XL Denali
BATESBURG, SC. 29006
29006
Some of my restorations
http://www.snapfish.com/snapfish/thu...NAME=snapfish/
Restored Tach tins 8 cyl - 6 cyl
http://67-72chevytrucks.com/vboard/s...d.php?t=518185
Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM
God Bless Our Troops
PT'S 70 CST is offline   Reply With Quote
Old 11-15-2012, 08:24 AM   #3
Ironhorse
Ironhorse's Avatar
I have #2 sbc upper clutch rod if you are referring to the long rod that goes thru the firewall from the clutch rod to the lower clutch portion. Some wear on the pivot points but still quite useable. Recently pulled from my '71 4x4 4 spd., converting to auto. $12 plus shipping
Also have #6 lower (and uppers) radiator retainers with useable rubber pads, for 2-3 core radiator $15 plus shipping for the set.
Also have upper and lowers for 4 core radiator retainers with useable rubber pads, $25 plus shipping for the set.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 11-15-2012, 11:43 AM   #4
SHANE 73Z
Thanks guys,
PMs sent to both of you.
Old 11-15-2012, 12:42 PM   #5
PT'S 70 CST
"GO DAWGS"
Just so we are on the same page, is this the plate you are looking for and if so I have one on some of my parts trucks but they are at my property about 15 miles from my house and I will be out there this weekend and can pull one off then. I have the two panel chrome pieces and will have to look in my parts trucks for the bezel because I could not find one here. The two switch bezels are very nice with no pitting.
PT
70 CST SWB
70 NOVA
2000 Silverado swb
29006
Old 11-15-2012, 02:10 PM   #6
Ironhorse
Ironhorse's Avatar
Pics of the clutch rod and radiator brackets. Pic shows the upper and lower brackets for the 2 & 3 core radiator. Have the upper 4 core brackets in the pic, have not removed the lower brackets from rad. support on truck I am parting but I DO have them. Clutch rod is just under 20'' in length and has a bit of a dog leg to it. Hope the pics show what you need.
Wellington, Ks
Old 11-15-2012, 03:10 PM   #7
SHANE 73Z
PT
PT,
Thanks for the quick reply. The plate is exactly what I am looking for, including the bumpers if possible.
As far as the bezels, I am looking for the other style that was available. If I understand correctly, the style I am looking for doesnt have the 2 square holes in the recess, but has 4 notches around the raised ring.
When you get your hands on the plate & bezel let me know.
Regards,
Shane
Old 11-15-2012, 03:14 PM   #8
SHANE 73Z
Ironhorse,
I am really only in need of the lower 4 core brackets. I intend to use an aftermarket cover for the top.
The clutch rod is exactly the one I am looking. When you get the lower brackets out, let me know & we can get them paid for.
Thanks again,
Shane
Old 11-15-2012, 07:23 PM   #9
Ironhorse
Ironhorse's Avatar
Shane, Would prefer to sell the upper and lower brackets as a set but if you want just the lower brackets I would do both lower brackets and the clutch rod for $25 plus shipping. Will need your zip code to figure a shipping cost. I don't have Paypal, use money orders when buying and selling on the board. If that is good for you let me know.
Wellington, Ks
Old 11-15-2012, 08:43 PM   #10
SHANE 73Z
You have a PM coming.
Shane
