11-15-2012, 01:01 PM | #1 |
Wood Bed in 63. Do I need frame tabs for cross sills?
Does anyone know where I can get just the cross sill pads or tabs.
These go on the frame under the cross sills then the wood bed bolts through. I can get them with new cross sills although don't need em. Can I make these frame tabs or some call them sill supports? Any suggestions? Do I need them? |
11-15-2012, 02:33 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Wood Bed in 63. Do I need frame tabs for cross sills?
Mar-K
pn120181
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-15-2012, 06:01 PM | #3 |
11-15-2012, 06:21 PM | #4 |
You can always make them if you have a brake and shear... MAR-K, Brothers or LMC most likely the easiest.
11-15-2012, 07:55 PM | #5 |
I have found the pad but not the metal brackets the pads go in. My truck was so rusted I can't tell what size they need to be. Are they about 6"x4" and will galvanized sheet metal metal work?
11-15-2012, 08:12 PM | #6 |
Take a pic of what you need I can cut some off of a frame I got pm me
Posted via Mobile Device |
11-15-2012, 08:28 PM | #7 |
It is a thin steel plate looks like sheet metal that the cross sill sit on and the pads go under it think. Mine have rusted away don't have them to take a picture. I saw them on a 65 yesterday at the local body shop that had the bed off
11-15-2012, 08:35 PM | #8 |
The bed bolts go through the wood and sill plates and then through these and then through the frame
11-15-2012, 09:06 PM | #9 |
hey jay, you going to make it down this weekend? if you are, we might be able to talk the guy who owns the junkyard into helping us out.let me know,jeff.
my 65 fleetside build http://67-72chevytrucks.com/vboard/s...d.php?t=442370 big back glass conversion http://67-72chevytrucks.com/vboard/s...dow+conversion |
