Old 11-15-2012, 03:28 PM   #1
SHANE 73Z
Headlight & Wiper switch bezels - 2 different styles?
Hey guys,
I have been searching for an answer to this but havent been able to find anything.
My LMC catalog shows 2 styles. One is the common chrome bezel with 2 square holes in the recess. I have seen & held these in my hand on several occasions.
The other appears to have 4 notches in the raised outer ring, without the square holes. I have yet to even find a picture of this style. What determined how a truck was equipped?
Thanks in advance,
Shane
SHANE 73Z is offline   Reply With Quote
Old 11-15-2012, 03:51 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Headlight & Wiper switch bezels - 2 different styles?
Sounds like you have seen both 67 and the 68-72 styles.The 67 is different from the others and the LMC catalog shows both.IIRC the switches themselves are the same.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-15-2012, 04:27 PM   #3
SHANE 73Z
PD,
Thanks for the heads up. Going from memory I believe the LMC cat shows that they are interchangable through all years, but doesnt specify what they are originally found on.
Take care,
Shane
Old 11-15-2012, 05:21 PM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: Headlight & Wiper switch bezels - 2 different styles?
Don't hold me to this but the differances are the 67 & 68 had a manual chock cable that mounted under the head light switch. After that went to auto chockes and no more cable. So the dash was redone with just head light and wipers.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-15-2012, 05:30 PM   #5
SHANE 73Z
Thanks Andy,
I know about the choke/wiper/headlight positioning through the years. I am putting together a 68 GMC and eliminating the choke. I was wondering about the differences in the bezel/nut that goes on after the dash panel is installed.
Also FYI the ones with manual choke, the choke is on the right & the headlight is upper right & wipers are lower right. I just tore them all out.
Shane
Old 11-15-2012, 05:43 PM   #6
GMCJOE
GMCJOE's Avatar
The only difference in the bezels is whether you want the choke cable or not. So if you are eliminating the choke and just want a bezel with headlight switch and wiper switch holes, you while have no problems.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 11-15-2012, 05:58 PM   #7
Portmod7
Portmod7's Avatar
No telling if the ones on my 68 are original or not, but the wiper switch bezel nut and the headlight switch bezel nut were different. One was "recessed" deeper on the front side of the nut as if to let the knob sit further down into the nut, otherwise they looked the same. Both had the square holes in the recess... Just throwing that out there, I know it's not the same situation the OP talked about, but may explain why they list different ones...
BUT, I don't think it made any difference which one I put where, as neither interfered with either knob, so I couldn't figure out why they are different...
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac
Portmod7 is offline   Reply With Quote
Old 11-15-2012, 08:35 PM   #8
Andy4639
Old member
Andy4639's Avatar
Talking Re: Headlight & Wiper switch bezels - 2 different styles?
OK, I thought u wanted to know about the dash itself. I haven't ever payed any attension to the nuts.
