Is this hole in the firewall stock?
I'm trying to figure out if this hole (the one that looks like it has bubble gum stuffed into it, to the top right of the speedo cable hole) is original. The truck is at the bodyshop and they're ready to start welding up this type of thing, but this is one we can't figure out.
If the hole was there from the factory, I'll just grommet it. But if its something the original owner drilled, I want to weld it up. But its my only truck so I have nothing to compare it to! Second pic is current state, first pic is how it was when I bought it. Thanks, Dave
Re: Is this hole in the firewall stock?
Dave,
From the look of that hole I would say it was added. But the pictures I have seem to indicate it is an enlargement of an existing hole. The source of the pictures is unknown other than the likely came from this board. Also have a '67 cab picture that shows the same small hole about that location. Sorry I cannot be exact but this is as much as I have.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Does this help? I think that is a hole someone drilled asits uneven and factory holes are perfect cut.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Don't think so, looks a little ragged compared to the others.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Here are a couple of underhood pictures that may help. But I really think that swarf indicates a dealer or post delivery enlargement.
#6 | |
What is the harness coming through the hole to the right of your speedo cable? Thanks, Gary
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
#7 | |
Cool, the reason I ask is my truck has a hole in the same place, but there is nothing in it. Always wondered what it would be for.
I think the op's hole was were a firewall pad retainer was but it has been opened up
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
