11-15-2012, 08:27 PM | #1 |
Transfer case pattern instructions
Does anyone know if the 4 x 4's always had transfer case shift pattern instructions on the glove box? Was that specific to any of the 67 to 72 years? I have a 68 and a 70 Suburban.
1969 Chev Longhorn Custom Camper 1955 Buick Century Estate Wagon 1963 Buick Riviera 1953 Chevy 3100 Panel 1967 C-20 V8 4 speed 1951 Willys Jeep Wagon 1956 Chevy Suburban |
11-15-2012, 08:49 PM | #2 |
20' Daredevil (Ret)
Re: Transfer case pattern instructions
My '72 has no such instructions on the glove box.... but the shift pattern is imprinted on the TC shifter knob.
11-15-2012, 09:16 PM | #3 |
Are you wondering what T-case you have?
11-16-2012, 08:36 AM | #4 |
Thank you, My shift knobs are plain without a pattern. Hate to sound bad but I do not know what tc's I have. They are both 3/4 ton and as far as I know the tc's are original. The shift pattern on the 68 is different than on the 70. Cannot recall which is which but I can look.
Is there a simple way to tell what tc is by looking at it from a creeper?
11-16-2012, 09:49 AM | #5 |
Look at the back of the tcase. If it has an external bearing cover above the output yolk its a 221. Its almost as if they put the cover on as an afterthought. Has about a 1inch diameter nipple sticking out of the center of it. The shift pattern on a 221 is from the firewall, toward the seat, 2h 4h N 4Lo.
1969 4x4 Nothing beats a good rock drill and some dynamite |
11-16-2012, 01:35 PM | #6 | |
11-16-2012, 09:20 PM | #7 |
The original case for a '68 would be the Rockwell 221 while the '70 would be a NP 205. Assuming they are original, but with your explanation that shift patterns were different, that seems to be the case.
11-16-2012, 09:31 PM | #8 |
My 67 had the transfer case shift pattern sticker on the ceiling just above the mirror bracket.
Currently truckless, previous trucks: 67 K20, 87 K10 aka V10 & 72 C10 |
11-16-2012, 10:39 PM | #9 |
Yelp on the roof on my 69, 2wd-N-4wd H then 4wd L.
Posted via Mobile Device |
11-26-2012, 08:17 PM | #10 |
Thanks folks. I think I have what I need now.
