Old 11-15-2012, 11:43 PM   #1
ZMAR
ZMAR's Avatar
SAS axle help
I've got a 92 swab 4x4 that Im wanting to do a sas. I've got an axle out of a 99 f250. All the kits say to use a Dana 60 out of an older ford. Can I use the 99 or keep looking?
71 c10 swb
ZMAR is offline   Reply With Quote
Old 11-15-2012, 11:46 PM   #2
ryanroo
ryanroo's Avatar
Re: SAS axle help
biggest issue is the wheel pattern. metric on the ford and hubcentric. outside of that im not sure if the spring spacing is the same. if not then the kits wont work and you would have to fab your own
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 11-15-2012, 11:49 PM   #3
ZMAR
ZMAR's Avatar
Re: SAS axle help
Ok I figured the frames might be different widths or somethin. I will email the guys at sky manufacturing and see
71 c10 swb
Old 11-16-2012, 02:54 AM   #4
andrewmp6
Re: SAS axle help
A f250 uses a dana 50 pass on it its a dana 60 with a dana 44 diff kinda weak.The dana 60 was in the f350 and f450 i think.As far as lug pattern i think you can swap it not real sure search around see what you find.
andrewmp6 is offline   Reply With Quote
Old 11-16-2012, 03:23 AM   #5
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: SAS axle help
Is it a ball joint or kingpin axle?
Rich
1972 K5 Blazer CST Click HERE
Old 11-16-2012, 07:07 AM   #6
b454rat
Re: SAS axle help
Biggest issue is steering. The older 60s had king pins, easy as bolting on a steering arm. The b/j 60s require a new knuckle or machining it so an arm can be bolted. I'd pass and get an older 60. It can be done, but be cheaper, easy and stronger to use an older one. Plus the fact that it uses metric rims. Hardcore wheeling might be an issue, as it does have weaker innards.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 11-16-2012, 07:18 AM   #7
andrewmp6
Re: SAS axle help
This might help you on what front axle to run http://offroaddesign.com/catalog/88-...Conversion.htm
Old 11-16-2012, 07:47 AM   #8
mcmlxix
mcmlxix's Avatar
Re: SAS axle help
http://www.pirate4x4.com/forum/axles...-arms-kit.html
Rich
Old 11-16-2012, 08:09 AM   #9
ZMAR
ZMAR's Avatar
Re: SAS axle help
Very very helpful! Thanks guys. Mits a 99 platinum that my buddy wrecked. The truck was payed off so it's just sittin in a lot behind his house. The axle is free if I want it was why I was asking
71 c10 swb
