11-15-2012, 11:49 PM | #1 |
Truck audio set ups
Lets see some trucks audio set up. I am looking for some ideas on how to run a nice audio system. Lets here about what subwoofers you got and highs and mids. Lets see what's in your truck audio wise. Yeah I know there nothing like the sound of V8 but we need something else to listen to on those long cruises. Thanks everyone.
Posted via Mobile Device |
11-16-2012, 05:47 PM | #2 |
Re: Truck audio set ups
Here are some pics of my mids and highs. I just installed this last weekend.
Alpine BT138HD Head Unit Infinity Kappa 6x9s Infinity Kappa 6.5s JL Audio XD 400/4 Amplifier. I will be working on the sub next. BLUE SQUARE |
11-16-2012, 05:54 PM | #3 |
Do the kick panels get in the way?
11-16-2012, 06:55 PM | #4 |
Mine has a GM Thefltlok CD player modded for an ipod plug-in from a 1999 Blazer (looks stock so no worries about a break-in...that was my first priority), head unit factory EQ curves were wiped clean using a JL Audio program and line level goes to an AudioControl passive crossover. Two Alpine PDX amps (hidden in the factory center console running factory Caddy Bose speakers from an 08 CTS (yes, don't laugh....they kick ass when hit with some amplified power @ 2 ohms!) with two 3.5 loudspeakers in the center, a Bose tweeter in each corner where the stock 3.5 used to be, 6" mids in each door and a custom subwoofer enclosure holding (2) 8" Kickers. nearly everything is 100% hidden so it looks dead stock when you get in-then this sound seems to come outa nowhere---that's how I like it.
11-16-2012, 07:52 PM | #5 |
I'm running a JVC digital receiver... No more CD's all over the seat, I just plug in a 16gb thumb drive and I got all my music.
I mounted 5 3/4 Kicker speakers in the botton panel of the doors and will never do that again... I couldn't believe how much crap is in there... lol But I got it done. I also installed a pair of soundstream tweeters right below the dash, high on the kick panels... I'll try to get some shots later for you. For the sub I went with a 8" JL Audio Microsub ported box. Paired that with a MTX mono block amp... It fits perfect behind the bench and slams like a 12. Last edited by story; 11-16-2012 at 08:01 PM. |
11-16-2012, 08:43 PM | #6 |
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
11-19-2012, 12:05 AM | #7 |
11-19-2012, 12:21 AM | #8 |
Parts and more parts
84 GMC with dual 8" Bazooka tubes behind the seat, 8" woofers in the bottom of the doors and a 6" and 2" speaker and tweet on the top of the doors. I started the install with Boston Accoustic speakers in the doors, but have upgraded to Kickers in the bottom.
Frank |
11-19-2012, 10:26 AM | #9 |
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
11-20-2012, 06:37 PM | #10 |
78K & 79C Jimmys
the 87 had this setup
tweets removed from 4X10s and put in little "project" boxes for better stageing made the subs in the early 90s
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
11-20-2012, 06:45 PM | #11 |
78K & 79C Jimmys
the 78 has this setup to finish
was gona use the old but better power and usb options etc
11-20-2012, 06:50 PM | #12 |
78K & 79C Jimmys
and the "stock" 79 with ashtrays removed
11-20-2012, 06:56 PM | #13 |
Rear Cab Corners
Shallow Mount Pionner Sub, Box, and Amp Kick Panels
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
11-22-2012, 10:59 PM | #14 |
Sony stereo, Rockford Fosgate amps, 8" sub woofer & front speakers, Pioneer rear speakers. My son built the enclosure & shelf for the sub.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
11-28-2012, 11:49 PM | #15 |
i really kinda dig that enclosure with the storage built in.... might have to steal a similar idea.
11-29-2012, 09:12 AM | #16 |
11-29-2012, 11:00 AM | #17 |
Makes me want to add storage to my box as well....hmm
11-29-2012, 01:15 PM | #18 |
*cough* post dimensions *cough*
11-29-2012, 01:23 PM | #19 |
That is a pretty awesome enclosure/storage bin. Very nice.
On the topic here, I see most of y'all have the aftermarket standard headunits (not the types that use stock dash configuration). Whats the modification process to fit in a new headunit? Remove dash and make some cuts? Easy? Difficult? Worth it? |
11-29-2012, 02:27 PM | #20 |
Remove the Dash Bezel and cut the hole to fit. You also will have to cut the metal of the dash to fit the stereo as well.... I actually attached my stereo to the dash itself and cut the bezel to fit over it by making the mounting bracket sit back on the cd unit.
This make it for a quick removal of the dash bezel without having to mess with the stereo
11-29-2012, 02:47 PM | #21 | |
11-29-2012, 02:51 PM | #22 |
Somewhere there is a plastic plate available that matches the factory bezel somewhat and has a DIN size slot in it. You still have to cut the factory bezel and metal supports behind, but the panel fits over the corner of the bezel with a nice clean looking fit. Damn if I can remember where I saw them though.
11-29-2012, 02:53 PM | #23 | |
11-29-2012, 09:18 PM | #24 |
I think mine looks pretty good, only took about a half hour
Chevy runs in my blood |
12-01-2012, 04:49 AM | #25 |
Still working on my tunes so far Rockford power 800 A4 2 Old school rockford's 12" subs hx2 5" & 4" mids.. Infinty tweets. |
