11-16-2012, 10:45 AM | #1 |
Head light issue.. "HELP"
Well the Blue Heeler has a weird issue no head lights, hi-beams work when clicked over. i thought it was the hi-beam switch so i put a new one in and same thing. i'm thinking it's gonna be head light switch. anyone been thru this one before? if you can help please do. thanks. oh yeah this is a 65 c-10
11-16-2012, 11:01 AM | #2 |
Re: Head light issue.. "HELP"
Try cleaning the plug at the Radiator Support. Unplug it and make sure there is a good connection
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
11-16-2012, 12:26 PM | #3 |
Proud Americano
check your grounds.clean and or replace the ground connections.
Tattooed Cuban Trailer Trash. putting the cart before the horse since 1964. |
11-16-2012, 12:46 PM | #4 |
Chevy Fleetside and QBA are right on!! Just had same issue. (Bad ground @ grill) clean clean clean those connections! Good luck!
11-16-2012, 06:25 PM | #5 |
Headlight switch is ok if high beams work.Check the dimmer switch output to see if you have power coming out of the switch. Low beams will be the tan or brown wire. The green is high beams. The other wire is coming from the headlight switch to the dimmer switch.
If all checks good there, check both sides of firewall bulkhead connection, then out to the radiator support plug in. |
11-16-2012, 07:17 PM | #6 | |
sam |
11-16-2012, 07:39 PM | #7 | |
Go Fast and Have Fun.!! My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185 |
