Old 11-16-2012, 12:40 PM   #1
camrycurt
camrycurt's Avatar
Replacing sending unit - will gas gush out?
I want to replace the sending unit in my in-cab gas tank and I'm wondering if I need to do anything to break the suction in the fuel line before I disconnect the hard line at the sending unit?
When I replaced my fuel pump gas gushed out of the line when I disconnected it, and I'm worried the same thing will happen again and I'd rather not soak my cab in gas if I can help it. So, to those that have done it, will I be OK just disconnecting the line or should I do something else first?
Thanks for the help!
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 11-16-2012, 12:51 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Replacing sending unit - will gas gush out?
Depends on how full the tank is. if its under a 1/2 it will be fine
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 11-16-2012, 01:06 PM   #3
tex_waco_usmc
Project Heaven in my 67!!!
Just to be on the safe side I would maybe crack the line at the fuel pump first. This will bleed off any pressure that might be in the lines, if there is any. But, as has been said already if it is below 1/2 a tank you should be ok.
tex_waco_usmc is offline   Reply With Quote
Old 11-16-2012, 01:55 PM   #4
cdowns
cdowns's Avatar
if planning on replacing sending unit i always use a new oring gasket as the old ones sometime fall apart and cannot b reused
Old 11-16-2012, 05:53 PM   #5
fireman064
fireman064's Avatar
Does your tank for lack of better words act like its under pressure when you open the gas cap? (spray a mist of fuel ) I'm curious how yours goes because I'm about to do the same project and I'm a complete newb. There is a good video on youtube of a guy changing his in a 69 or 70. Made it seem straight forward. Keep me posted thanks
fireman064 is offline   Reply With Quote
Old 11-17-2012, 12:30 AM   #6
oklalawnboy
oklalawnboy's Avatar
You should be fine as long as fuel level is below sending unit (1/2 is great safe point). Loosen the cap to let off any pressure in the tank itself. If you crack the line at the fuel pump, it will likely just sipon fuel. The line on the tank side(feed) of the pump is the suction side so should be no pressure. There may be an oz or two just from the line but a couple shop rags should take care of that. Good luck.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 11-17-2012, 09:48 AM   #7
Daddy'O
Daddy'O's Avatar
Subscribed –
This is perfect timing as we are going to be replacing the sending unit in ‘Nancy’ tomorrow. Looks like I need to siphon some fuel before we start.
I’ve got a new gasket and lock ring. Are there any other heads up suggestions from those that have performed this procedure before?
Thanks!
Cheers - Wayne
Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966
'55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157
1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy"
1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55
Nothing sucks more than that moment during an argument when you realize you're wrong.
Daddy'O is offline   Reply With Quote
Old 11-18-2012, 09:03 PM   #8
Daddy'O
Daddy'O's Avatar
Got this done today. Siphoned 15 gallons of fuel out. Removed the seat & went to work. No fuel gushing at all, in fact not a drip got in the cab. The 41 + year old float was full of fuel. Replaced - and voila' the fuel gauge is now functioning correctly. Not too bad - maybe $50 total spent (I bought the tool to remove the lock ring) to have a functioning gauge.
Cheers - Wayne
Old 11-20-2012, 11:10 AM   #9
camrycurt
camrycurt's Avatar
Cool. Thanks to everyone for the replies and to Daddy'O for giving it a successful test run. Glad to hear everything went well!
Sounds like I'm going to run the fuel down low and swap it out with no problems. I won't know what to do with myself with a functioning gas gauge...
Thanks again!
Curt
Old 11-20-2012, 08:29 PM   #10
Daddy'O
Daddy'O's Avatar
Let us know how it goes for you.
Good luck!
Cheers - Wayne
Old 11-20-2012, 09:35 PM   #11
69GWC
Very simple to do, I did mine in about 20min .
69GWC is offline   Reply With Quote
Old 11-20-2012, 10:07 PM   #12
Daddy'O
Daddy'O's Avatar
69GWC is correct - If you take the time away from the siphoning - it took us only 45 minutes (I'm older and slower). That includes removing and replacing the seat.
Cheers - Wayne
