11-16-2012, 12:49 PM | #1 |
RAT1968 '68 Cab/'71 Parts
Lost Parts...Boy, Am I Stupid
I'm the happy owner of a new tilt by Forum Guru KevsClassics....Pristine workmanship. But, during the install,
I did something very stupid. Then, after I did that, I did another stupid thing. The first one is that I left out the spring and washer that sets the preload where the lower shaft and column meet! Second, is that I had to move everything from the shop to home and I lost these parts. Anyone know where I can find #19 and #20? Or, does anyone know what kind of off-the-shelf hardware, if any, I can use to replace them?
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
11-16-2012, 02:01 PM | #2 |
member #16
Re: Lost Parts...Boy, Am I Stupid
My tilt column does not have the spring and washer on the bottom like the non-tilt columns. It has a bearing retainer. Your pic looks like non-tilt column to me.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
11-16-2012, 03:31 PM | #3 | |
The one pic shows where there is a "tolerance" that will move (as pictured, UNDER 1/16"). It does not move "fore and aft", only up and down or side to side when you wiggle it with your hand. It makes a little "clunk". That's where I thought the preload spring went to keep that from happening. But, it seems like since the "movement" is on a more-or-less "horizontal axis", the preload of fore and aft would be less likely to be necessary. What do I do to keep this from moving at all? Except, when I turn the steering wheel!
11-16-2012, 07:03 PM | #4 |
Maybe the best question would be.......
Is there a difference between: A tilt column lower shaft, (from the intermediate coupler to the rag joint) - from - A non-tilt column lower shaft (from the intermediate coupler to the rag joint)?
11-16-2012, 07:43 PM | #5 |
My understanding is the intermediate shaft is the same.
When I assembled my tilt to the shaft I used the spring and thick washer, it does not take up all the room so no tension on the bearing in question.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
11-16-2012, 08:17 PM | #6 |
member #16
Do you have the movement at the top or bottom of the column? The brg adjustment nut at the top should remove the vertical movement.
11-16-2012, 10:02 PM | #7 | |
I don't know what the "bearing adjustment nut" is. Maybe an adjustment in the adapter behind the retainer? The movement seemed to lessen a little when I tightened the lower shaft's intermediate coupler bolt. But I don't want to tighten down on that too much thinking it's a "fix"... .....Unless it is! Hahahaha!
11-17-2012, 06:43 PM | #8 |
member #16
Well I don't know about movement in the lower column. I have never tried to find any on mine. It could be normal. It doesn't sound like you have any play at the steering wheel. Here's a pic of the upper brg adj nut I found in another thread. if it was off you would have up and down and side play in the wheel.
