Old 11-16-2012, 03:42 PM   #1
3r!c84
Badass
3r!c84's Avatar
installing rear glass
is there any tricks to put this glass in? its a 1 peice rear glass window. and just the rubber seal no locking chrome strip..
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-16-2012, 03:44 PM   #2
cory d
cory d's Avatar
Re: installing rear glass
windsheilds are easy, i tried a back window without a lock strip and gave up
cory d is offline   Reply With Quote
Old 11-16-2012, 03:58 PM   #3
bigblock73
yeller
bigblock73's Avatar
soap it and rope it...back windows are pretty easy.
bigblock73 is offline   Reply With Quote
Old 11-16-2012, 04:21 PM   #4
68JOHNDEERE
What bigblock said, be careful in the corners not to ripe the gasket then you'll have a bathtub. You can use a spray bottle with water and a couple of drops of dish soap to lubricate the gasket.
68JOHNDEERE is offline   Reply With Quote
Old 11-16-2012, 04:57 PM   #5
3r!c84
Badass
3r!c84's Avatar
im not getting what to do with the rope lol any more info?
-00 Saturn 5spd
1/4:13:90
Old 11-16-2012, 05:02 PM   #6
68JOHNDEERE
You put the gasket on the back window, then you take a 3/8 thick rope and put that in the groove of the gasket that the metal body of the truck goes. With help someone holds the glass into the opening from the outside while you pull the rope into the cab thus bringing the rubber lip of the gasket over the metal to lock it into the cab of the truck.
Old 11-16-2012, 06:02 PM   #7
jimboh247
jimboh247's Avatar
Just be patient!! and use lots of soapy water to lube it up! And have someone working with you that can hold the glass where it needs to be held until you get started. I had my wife attempt to help me.....fail
'85 SWB Silverado
jimboh247 is offline   Reply With Quote
Old 11-16-2012, 06:36 PM   #8
3r!c84
Badass
3r!c84's Avatar
this video sums it up i think going to give it a try in a few days
https://www.youtube.com/watch?v=QvcJ_lU_VpQ
-00 Saturn 5spd
1/4:13:90
Old 11-17-2012, 12:44 AM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
I used weed whacker string. Wrap the string/rope around the gasket. Slip the bottom of the glass into the pinch weld and start pulling.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is online now   Reply With Quote
Old 11-17-2012, 08:17 AM   #10
bigd65
bigd65's Avatar
Excellent video. I need to swap out a slider for a solid window
2004 Silverado Crewcab (Dark Spiral Gray)
bigd65 is offline   Reply With Quote
