Heat Control Cable Clip
Greetings,
Drove the truck today. It was 40-degrees when I left to pick up the new snow tires for my DD-car. Anyway, went to move the heat lever, and I could feel it slip off the door. I was able to manually open the heat door, (good thing). As I recall I found a clip at the local hardware that I thought would work. Guess I was wrong. Went looking at several online shops but cannot find the clip. Anyone know were to get this? Thanks
MrBlue 72' C-10 350 TKO-600 Current Project 54' Ford F-100 Life Long Project |
Re: Heat Control Cable Clip
I would check the local hardware stores as the local Ace Hardware here has an assortment of the clips which includes the size you need.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Most of the after market places have them but not always in the catalog or findable online. It's an odd size, I have not found they at hardware stores. I have gotten them from the truck shop in Orange California, call them.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Maybe measure the post that the cable mounts to and find the oldest hardware store in your area and they will more than likely have the size press nut you need or something you could make work. Good luck, Pat
Posted via Mobile Device |
These are the same, they are reproduced for first gen Camaro. I have a pile of NOS ones too in correct black finish (pic #2).
http://www.heartbeatcitycamaro.com/s...ble-retainers/ GM p/n 381700
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
