Truck won't turn over, good battery, tried to jump?
Ok, here's the scenario: Took the child bride in the 72 GMC to see Lincoln tonight ( great movie, long almost 2.5 hours), walked out to the back row, (don't need any door dings from those super duties) all is good, it's where I left it. Stick the key in the ignition, nothing other than my park brake light is glowing? Dome light works, radio turns on, horn honks?
So, I call the baby girl to bring the jumper cables, she show's up in a flash,(just like baby girls are suppose to). Hook up the cables (yes, I've done this untold times over the course of the last 58 years). Nothing! Absolutely nothing! No clicks, nothing??? So, I leave my perfectly good 72 sitting in the parking lot at 11:00pm and come home, to ponder my predicament. So, assuming that the truck is still in the movie parking lot in the morning, with my brand new wheels and tires still on it, what do you guys think is the problem? Big Texas thanks in advance. Oh, and here's a pic just so you know that you'll be helping a good cause. ![]()
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
Re: Truck won't turn over, good battery, tried to jump?
Sounds like an ignition switch problem. If it were me I'd get that towed home pronto. Leaving a truck like that overnight in a parking lot is just asking for a loss. At a minimum grab a ride back and keep it company.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Yeah really. Take a blanket and pillow, go park next to it, and spend the night
Posted via Mobile Device |
Ok, you guys made me reach deep down inside of myself, go coax the child bride out of bed and go get the truck (she is such a good sport). Grabbed my circa 1979 custom made tow rope and headed out in her Lexus.
Yea!! the 72 is still where I left it, sitting on it's still intact tires! Tried to start it, still nothing. So, child bride graciously helped me push it back so that I can attach the rope to the truck and her car. We start for home and after about 100 yards I decide to try the key again....................here it comes................it starts!!!!!!! ![]() Get home shut it off, start it, shut it off, start it. WTF??????? What do you think? Still the starter switch? PS Mister-B....Child bride told me the same thing.
Its probably the ignition switch. Glad to hear you still have a truck with wheels even.
i would clean the positve battery cable both ends first and all the connections on the starter
there is no parking brake light on your dashboard from the factory in 72
if an automatic tranny check the neutral safety switch too
Junior Member
I had the same problem and a whack with a hammer on the starter got it going. Since the starter was under warranty I just got another one and have not had a problem since.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Yep, if its an auto, make sure it is all the way in park . My 68 gmc does it all the time, I consider that my security system now....or try tapping the starter when someone is trying to start it.
Question, I'm assuming the truck will normally start in the "Neutral" position? I was being towed when I started it. Hmmmmmm?
20' Daredevil (Ret)
![]() Join Date: May 2003
Yes -- the Neutral Safety Switch allows starting in either Park or Neutral.
I like this idea. Usually works once or twice.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
#13 |
Update: I've driven the truck all day and not a sign of any problem. Grimlins?
#14 |
![]() Join Date: May 2012
if its not a battery connection, i would say pull the starter and check inside. could be brushes, or starter solenoid.
#15 |
If you suspect the nss you could always just make a jummper wire and bypass the nss to see if thats the problem.Keep the wire in your glove box just incase.
#16 |
![]() Join Date: Jun 2012
i had the same problem twice....i hit the starter the first time, problem solved....the second time, i realized when i put my truck in park, the shifter moves slightly to reverse....i now always check the shifter, its an ocd habit i have really lol
#17 |
My truck did this since I got it. If you ever have this problem again just hold up on the gear selector so it's in park. First time mine did that I almost went crazy looking for the problem...now it's just my anti theft device also
![]() Posted via Mobile Device
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. " |
#18 |
Update: Day 2 drove the truck on and off today......started flawlessly. I hate this. I'd rather fix it than wonder when or if it will happen again.
