Rim size
I found some aluminum rims for sell but they are 16" will they work on my 1966 C10 step side short bed.
Thanks for the input Rocky |
Re: Rim size
Maybe, maybe not.
If they're 6 bolt maybe! Newer ones maybe not! Offset won't work or centre bore too small. Got a pic!! |
Re: Rim size
Try these links I hope they work I'am not good with these things.
http://img.bonnint.net/c/2438/243819...r=ksl/gallery1 http://www.ksl.com/index.php?nid=218...99&ad=22679004 |
Re: Rim size
Looks like they'll work.
Get him to measure the centre bore. How wide are they? Price is a bit high for just the rims. |
Re: Rim size
You can buy similiar ones for the same price in 15" for 300 bucks too.
http://www.ebay.com/itm/15X8-BAJA-ST...1ef140&vxp=mtr |
Re: Rim size
Those rims you found are an alloy not aluminum I will search for some aluminum. I think the rims are an 8" but I would have to ask I didn't because of the 16" and not knowing if 16's would fit under my truck. That is what the concern is will they rib and be to high. I know they will bolt on but will they work well.
Re: Rim size
I have a 63' and it has 265/70/16 and they fit fine but it is a 4x4 with a 4 inch lift. If it is a private seller ask if you can drive out and put them on to see if they will fit first. A 305 is kind of wide and may rub when the steering wheel is turned.
#8 | |
Re: Rim size
Posted via Mobile Device |
Re: Rim size
Thanks Mack maybe I will just stick with the 15s there are four 15" (posted link)I looked them up on the internet and new they cost 212.00 ea I tried to get him to come down a little but I don't think he will.
What do all of you think about these. http://www.ksl.com/index.php?nid=218...99&ad=19232878 |
Re: Rim size
i took the stock rims and tires lt265/75/r16 off my 1995 chevy k2500 and tried them on my 1966 chevy c-20. the c-20 has the 17.5 rims and tires , , the 95 rims have a back spacing of 4" , and the 66 rim has a back spacing of 5" , the 95's fit and looked good , no rubbing anywhere , but stuck out further by 1/2 in. they worked pretty good , just to give you some ideal .
Re: Rim size
Wow you did that for me??
That is one thing that I also wondered about do the 16s look cooler then the 15s what did you think? And when you say the c20 has 17.5 rims do you mean width? And is there any difference between the c20 and c10 as far as clearance. Height wise I think I would be fine but if I make a sharp turn that would be the problem. |
Re: Rim size
the 16's do look cooler. the 17.5's are the original rims , i think there somewhere in the 61/2- 7" with , they seem skinny. the c-20 should be a bigger tire size over a c-10. well i turned my wheels back and for and got under there and looked and it did not look to be rubbing anywhere , it looked like it had about 2" clearance on the fronts. when i put the 16" on the rear it moved out further than the stock rim by 1/2 " , it was a little close to the outer bed metal by 1" but it was centered right in the middle of the tubs.
#13 |
Who Me?
Re: Rim size
If the bolt pattern is correct which I suspect it is, you will need to look at what lug nuts you will need. Alum rims usually have a think mounting area and the lugs reach thru the hole instead of a tapered hole like on steel rims.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#14 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Rim size
Aluminum and alloy are just 2 names for basically the same thing. Some people call them aluminum wheels, others call them alloy wheels. All Aluminum wheels are made from an aluminum alloy.
The diameter of the wheels is not as much of a determing factor in fitment as is what size tire is on the wheels. Those wheels with the 305/70R16 tires might cause clearance issues. But then they may not too. Another factor is what the ride height is of your truck.
