Electrical ID
Hey guys, I have a 63' that I am putting a steering column in that is from a 72' to replace the one someone installed from a mid 70's Impalla...I was hoping you guys would be able to help me ID the eight wires that come from the 72' column. There is also a ninth wire further up that I believe is for the light in the PRND21 indicator..the column is all stock with the harness connector but my truck has an aftermarket wiring harness and the leads are all labeled. I just need to know what the ones on the column are. There is no key on the column, it is in my dash. Also I saw that wiring diagram on this site that someone made but It does not identify what all the wires are...
Re: Electrical ID
Bump...can anyone help me on this...
Old member
I think this maybe it. Not sure but it looks correct and it's for a 72 chevy truck.
TURN SIGNAL SECTION GM Designation Blk Horn Lt.Blu LF Turn Signal Dk.Blu RF Turn Signal Brn Hazard Flasher Pur Turn Flasher Ylw LR Turn Signal Grn RR Turn Signal Wht Stop Lamp Switch ![]() ![]() Here is where I got the info. http://www.painlesswiring.com/Manuals/10206.pdf
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 11-17-2012 at 11:43 PM. |
Re: Electrical ID
Hey thank you very much. That is exactly what I am looking for. There is also a lot of other really usefull info in that link.
![]() Join Date: Nov 2012
Re: Electrical ID
I don't know for sure if this applies to your column, but I stumbled onto it here. Good luck.
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
#6 | |
Re: Electrical ID
Re: Electrical ID
Wiring in the column has nothing to do with transmission They are the same
69 Chevy 4x4 383 Power ![]() |
Re: Electrical ID
thankzzz
