Old 11-17-2012, 05:07 PM   #1
Chevyman350
Dually Fender Bolts
What are you dually guy's using to attach your dually fenders to the bed.
Alot of my origional hanger bolts were rusted and stuch and broke or I had to cut off.
The joys of the rust belt
What size, thread length, how to install adhesives etc.
Thanks!
Chevyman350 is offline   Reply With Quote
Old 11-17-2012, 05:37 PM   #2
Desert1957
Desert1957's Avatar
Re: Dually Fender Bolts
Bolts are 5/16" coarse thread , about 5/8" out of hole
I can't imagine trusting them glued on, but I guess you could , today's epoxies are heavy duty enough to hold it.
Desert
Desert1957 is offline   Reply With Quote
Old 11-18-2012, 05:46 PM   #3
Chevyman350
I was wondering if anybody had to replace any I have a few that have come completly out of the fiberglass and need to be replaced.
Any thoughts?
Would you epoxy a hanger bolt? Look to GM for a part number?
Epoxy in a piece of all thread?
Old 11-19-2012, 03:19 AM   #4
Big-Sexy907
Desert, that bolt looks brand new! How/where did you find a fender in that condition?
Has anyone figured out what kind of gasket/seam sealer is used to attach the fender to the bedside?
Big-Sexy907 is offline   Reply With Quote
Old 11-19-2012, 09:36 AM   #5
bk2life
looks like an az fender..
i have had a few come out, i just use panel bond and put them back in. havent had any problems.
bk2life is offline   Reply With Quote
Old 11-19-2012, 10:07 AM   #6
rs72z
rs72z's Avatar
One of the fenders i used on my truck came from Iowa and it had a bunch of bolts rusted off and some that the glass was busted on. I was able to get the broken bolts out, they are a coarse thread like a lag bolt where they screw into the glass at. I went to the local hardware store and found some studs that were lag thread on one end and fine thread on the other. I then used some panel bond inside the fiberglass holes before i screwed the stud in.
Worked great.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 11-19-2012, 01:22 PM   #7
Desert1957
Desert1957's Avatar
I purchased them a few year back, They are NOS gm originals. There are some on Ebay now but, get ready for sticker shock!
My body shop guys said regular seam sealer after you bolt them on , sand, primer and paint.
Desert
Old 11-19-2012, 01:26 PM   #8
Desert1957
Desert1957's Avatar
Any thoughts?
I thought you were asking if they could be held on with adhesives in your first posting, that's why I replied with my comment about gluing them on.
Desert
Old 11-19-2012, 02:19 PM   #9
Chevyman350
Desert
Not a big deal, I have been wondering how to repair mine for awhile and was just throwing some concepts out there to see what everybody has done?
Old 11-20-2012, 12:06 AM   #10
Big-Sexy907
Desert
Now my question is, do you use the seam sealer before or after you paint the fender?
Old 11-20-2012, 08:48 AM   #11
Desert1957
Desert1957's Avatar
Both Duallies I have seen have paint on the seam sealer, They look like Fenders were mounted, Then seam sealer added , Smoothed out and painted.
But after saying that, I have seen a repainted truck where the fenders were painted separately, then mounted , It looked OK also.
Desert
Old 06-16-2013, 04:09 PM   #12
woffis
Hi
I am restoring a K3500 dually and i really need new bolts like the one earlier in this thread.
So do anyone know where i can buy some?
I live in sweden so i will be really happu if anyone will help me with this problem!
sorry my bad spelling
Kristoffer
woffis is offline   Reply With Quote
Old 06-17-2013, 06:35 AM   #13
Desert1957
Desert1957's Avatar
Originally Posted by woffis View Post
Hi
Kristoffer
The picture I posted earlier in this thread was of a brand new fender. It only came with the side studs, the row across the top edge I tapped out with a 5/16 tap and installed studs.
Desert
