Old 11-17-2012, 06:47 PM   #1
melhilburn
melhilburn's Avatar
Door check problems
Need to replace the driver side door check - how much of the door do you disassemble to get the job done?? - Just want to make sure I'm headed in the right direction.
melhilburn is offline   Reply With Quote
Old 11-17-2012, 06:58 PM   #2
MusicMan70
MusicMan70's Avatar
Re: Door check problems
Door check this; then stand back and say, "Would you look at that!"
http://www.persh.org/pickup/DoorChecks.htm
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 11-18-2012, 12:27 AM   #3
donthekawguy
donthekawguy's Avatar
I just did my passenger side about a week ago. Take off the handles, panel roll the window up and you should be able to reach in to replace it. The hardest part is getting the screws started that hold it to the door.
66 shorty
donthekawguy is offline   Reply With Quote
Old 11-18-2012, 02:01 AM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
My '65 I pulled the door panel and handles. Remove the pin and two screws. Replace with new one. I used the Jeep Cherokee front 4 door ones. This prevents the doors from opening too far and gives me two "stops" to hold the door open. Works great! Took me about 5 minutes per side.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-18-2012, 05:24 PM   #5
melhilburn
melhilburn's Avatar
This is fantastic! - thanks for all the help.
