11-17-2012, 07:56 PM | #1 |
Courtesy light installation problem
I just bought NOS door jamb switches and a NOS wiring harness to install in my 81 shortbed that did not come equipped with them. The door switches are installed, but I see no way to run the wiring to them in the door jamb. I thought the "kick panels" would have access holes behind them, but not so, only metal barriers. How do I get these wires in the proper place?
11-17-2012, 08:22 PM | #2 |
Re: Courtesy light installation problem
There is a hole in the pillar underneath the dash. It's kind of mean to reach and feed wires down but do-able.
11-17-2012, 08:36 PM | #3 |
Thanks Zebb. I found it thanks to your reply!
11-17-2012, 10:01 PM | #4 |
The reason I could not initially find these wiring holes is because they were PLUGGED WITH METAL PLUGS as well as hidden deep inside the under-dash. Popped them out with a flathead and in went the wires! I guess option-less trucks like mine had these ridiculous things!
11-18-2012, 04:59 PM | #5 |
OK, next issue. The NOS wiring harness is installed but I have no idea where to attach the orange wire harness plug to the fuse box. It fits in several places, but does not get any power. Also, there is a brass-color "folded blade" type wire attachment on the harness white wire that is even with the passenger-side of the truck. This "folded blade" thing is not on the end of the wire, it is about 25 inches from the bullet-plug for the passenger side courtesy light door switch. What is supposed to attach to this? BTW I have checked multiple wiring diagrams and they were NO help.
11-18-2012, 09:44 PM | #6 |
One wire goes in the headlight switch connector...turn the deadlight dimmer to the end and then there is a distinct on off then the dome, under dash courtesy lamp turns on.
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A |
11-18-2012, 10:06 PM | #7 |
The wiring diagram shows an attachment to a light switch that is right BESIDE two door ajar switches. Would it be OK to forget the fuse box and run a hotwire using an inline fuse? I HATE dealing with fuse boxes. I have not even figured out how to attach this wire to my one dash courtesy light because no plug is visible anywhere. It is attached to the light switch already. I am beginning to wonder if I installed the wiring harness backwards. The large wire that attaches to a dome light (I think) is wired so that it is on the driver side. Hope that is right.
11-18-2012, 11:35 PM | #8 | |
