Old 11-17-2012, 08:04 PM   #1
Arl37
Do I need a Puller or tie rod separator?
Going to replace manual with power steering. I need to remove the end of the pitman arm that is not attached to the gear box. Will a tie rod separator do the job or do I neeed a puller?
Arl37 is offline   Reply With Quote
Old 11-17-2012, 08:31 PM   #2
truckster
truckster's Avatar
Re: Do I need a Puller or tie rod separator?
I use a pickle fork. I cheat, though, because my pickle fork is on an air chisel.
truckster is offline   Reply With Quote
Old 11-17-2012, 08:55 PM   #3
1972SUPERSB
1972SUPERSB's Avatar
Yeah we he said above just use a tie rod separator hit it a few times with a mini sledge hammer and it will pop right out
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 11-18-2012, 01:28 AM   #4
WIDESIDE72
WIDESIDE72's Avatar
Before you go to the trouble be sure that arm is the same for power vs non power. I always use a puller but heat the arm around the sahft with a toruch first. Of course you run the risk of burning up the seals on the old box, but if it is going in the scrap pile anyway, who cares?
WIDESIDE72 is offline   Reply With Quote
Old 11-18-2012, 07:10 AM   #5
jjzepplin
jjzepplin's Avatar
I loosen the bolt almost all the way. Then a sharp thwak with a mini sledge. No problem. I have a real nice Snap-On pickle fork but it never gets used.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-18-2012, 08:05 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The pitman arms are different.
