Old 11-17-2012, 08:11 PM   #1
Andy4639
Old member
Andy4639's Avatar
Wink 71 Cold air Intake Pic's
I was thinking about how many have true cold air intakes on their rides. I'd like to see them. I want to see some idea's about what u have fabbed up are bought.
I built mine out of a 90 Caddy air box. I sealed the factory opening up and cut a 4" hole in the bottom of it and used a ninty fitting with 2 couplings from Lowes. I drilled a 4" hole in the radiator support where the voltage regulator would have been but since I went to a alternator with it built into it I had the perfect spot for it.
Let's see what you got guy's!
You can see the sheet metal that I used to fill the factory opening.
This shows the flange for the ninty to be installed.
Support hole cut.
This has the coupling through the support to slip the ninty onto it.
This is it mounted.
K&N filter installed.
Top and intake hose installed.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-17-2012, 09:54 PM   #2
72 K20
72 K20's Avatar
Re: 71 Cold air Intake Pic's
Please show a pic of the connection to the engine !!
Thank You !!
72 K20 is offline   Reply With Quote
Old 11-17-2012, 09:56 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: 71 Cold air Intake Pic's
Here you go.
Old 11-17-2012, 11:14 PM   #4
72 K20
72 K20's Avatar
Very nice !
Speed density setup ?
Which wire harness did you run ?
What kind of mileage are you getting ?
Thank You !!
Tom
Old 11-17-2012, 11:23 PM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: 71 Cold air Intake Pic's
Map senor
Which wire harness did you run?
Speed & Performance. V-6 Feiro computer with S&P chip to run a V-8.
Around town 15MPG Highway 18
Thank You !!
Tom
Your welcome.
Old 11-17-2012, 11:24 PM   #6
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Thank You !!
For some reason the picture is missing, as is the one for the K&N filter
I am liking the other work, nice job!
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 11-17-2012, 11:42 PM   #7
Andy4639
Old member
Andy4639's Avatar
They are showing in my post but here let's try again then.If they aren't showing up you may have a pop up blocker on.
Old 11-17-2012, 11:44 PM   #8
ole dollor
ole dollor's Avatar
i like it....really looks nice, ya did a great job.
ole dollor is offline   Reply With Quote
Old 11-17-2012, 11:48 PM   #9
chevytruckluver
Now they are there, what is the adaptor on the throttle body?
again, nice work!
Trey
72 Short Step
Old 11-17-2012, 11:54 PM   #10
Andy4639
Old member
Andy4639's Avatar
again, nice work!
You have to explain what you mean by adapter. The motor is a basic all factory setup with no adapter that I know of.
The intake hose is connected to the throttle body by a radiator clamp and a ninty rubber fitting I bought at O-Reilly's auto parts. if this is what you are refering to. It's a 3" rubber ninty for cold air hookups.
Old 11-17-2012, 11:55 PM   #11
Andy4639
Old member
Andy4639's Avatar
Thanks man. I try.
Old 11-17-2012, 11:59 PM   #12
chevytruckluver
Yes, thats what I was talking about 3" rubber 90
Trey
72 Short Step
Old 11-18-2012, 03:55 PM   #13
Andy4639
Old member
Andy4639's Avatar
Question Re: 71 Cold air Intake Pic's
You can buy them through just about any parts store.OK where are the rest of the intake setup's? I know I'm not the only one on here with a cold air intake.
