timing engine -what does it mean when engine is sucking air through exaust ports
im rebuilding a 350 and i put the starter on it to turn it over. I put my finger over the #1 spark plug hole but it doesnt push any air out. But it is sucking air through the exaust ports on the head. there are no spark plugs in the engine right now.Does anyone know what the problem is ? i lined up timing marks am i 180 out?
thanks
Re: timing engine -what does it mean when engine is sucking air through exaust ports
You put the timing gears dot to dot?
yes dot to dot
You might double check, but I dont think dot to dot is correct on a lot of timing gears. For some reason its striking me as a mistake Ive almost made, and it would make it 180 out.
hmm so thats the only thing that would cause it?
![]() Join Date: Sep 2010
If your exhaust is sucking in your chain is on wrong. Does the same thing when the wear off and skip a tooth. Pop it off and take a look at it.
1985 c10 355 th350 (working on 4 speed conversion to super t10) 1979 camaro 358 super t10 2003 f250 superchip slp exhaust |
18 Till I Die
Dot to Dot is ok. You just need to find TDC and re-install the dizzy to #1.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
Be safe and degree the cam with the intake centerline method.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Moderator
![]() Join Date: Jul 2006
Valves are adjusted incorrectly.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
![]() Join Date: Apr 2009
Here is a Pic of a Dual Roller setup, but you get the idea.
![]() Also recheck the valve adjustment like suggested earlier in this thread, rotate the engine over (by hand) spinning the push-rods with your fingers for intial lash, then due your 1/2 or 3/4 turn preload. Desert |
I think you all thinking way too much. Turn the the crank in the proper direction and it should be exhausting through that port
#12 | |
Desert |
#13 |
Thats the only way I know an engine will draw in air from the exhaust port. If he's using the starter then he has a boat cam that is designed to be rotating in the oposite direction. I.e. a boat with twin engines.
