11-17-2012, 08:24 PM | #1 |
new needle valve could be sticking?
i put a new needle valve in my holly 4412. when i blow through the fuel line it works as it should shutting off the flow as i lift the bowl. but when i let the bowl go down it sticks, and i have to blow hard to get it to unseat. is the fuel preasure gunna be enough to push through it? ..
12-17-2012, 06:52 AM | #2 |
It's alsways something.....
Re: new needle valve could be sticking?
Jake, I have found that this is a result of ethanol in the Gasoline. I have the same trouble in my forklift- I finally bought non-ethanol at a local station after I got tired of having to take the carb top off. Id recommend that you buy some "stabil" and put in your tank to lube the needle and seat- HTH
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
