Old 11-17-2012, 08:37 PM   #1
ECU PIRATE
ECU PIRATE's Avatar
Manual tranny swap
Finally got around to dropping in my Muncie tranny after two years of talking about it. To get the hole in the tranny mount to line up with the hole in the crossmember, I had to disconnect the motor mounts from the frame and move them back. At lest the tranny is in and the driveshaft is hooked up. Anyone run into this problem before? May need to drill new holes in the frame and engine crossmember to get everything buttoned down.
Thanks,
Mike
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 11-17-2012, 08:48 PM   #2
Seventy
Re: Manual tranny swap
Not that there is a wrong way, if youre building it custom to your liking. Typically though, you leave the engine placement the same, and move the transmission crossmember, then shorten/lengthen the driveshaft.
Moving your motor rearward isnt a bad thing, if everything clears, you just took the less traveled route.
Seventy is offline   Reply With Quote
Old 11-18-2012, 01:39 AM   #3
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
There are usually different holes in the frame for different transmission options.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 11-19-2012, 08:27 AM   #4
ECU PIRATE
ECU PIRATE's Avatar
some shots
The Fleet........
Old 11-19-2012, 08:44 AM   #5
SSC's76
No No
SSC's76's Avatar
might be a stupid question not knowing all the details but this trans should bolt up exactly where a th350 did as far as crossmember placement what kinda trans did you have in it before?
Posted from 67-72chevytrucks.com App for Android
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 11-19-2012, 08:51 AM   #6
ECU PIRATE
ECU PIRATE's Avatar
There are never stupid questions. I had an Olds 260/TH200 combo in there before
The Fleet........
Old 11-19-2012, 09:01 AM   #7
ECU PIRATE
ECU PIRATE's Avatar
Should be exactly 1/4" bell housing to mount difference between the TH200 (20 1/8") and the TH350 (20 3/8"). This is what I was off. My truck was originally a 6 banger with a TH350
The Fleet........
Old 11-19-2012, 10:51 AM   #8
Seventy
Pirate, have you drilled your front crossmember already? If you only have 1/4 inch difference, that isnt going to put much distance between your old and new motor mount holes. I'd be alittle concerned with swiss cheesing it up too much.
Probably will be fine, Im just anal like that.
Also, its cool you finally got it installed. Granted I just joined, but awhile back I was searching about putting a muincie in mine, and came across your older threads.
Old 11-19-2012, 11:34 AM   #9
ECU PIRATE
ECU PIRATE's Avatar
Haven't drilled jack yet Seventy. Just trying to get some ideas. I know it is an easy fix. The bed is coming off soon so, I may just on bolt the cab and raise to to get some of the tension off the frame and square up the crossmember. Either that or replace it..........
The Fleet........
Old 11-20-2012, 10:08 AM   #10
swb85
On a budget like Fred Sanford
swb85's Avatar
Woohoo for progress! You'll be banging gears before ya know it.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 11-20-2012, 04:29 PM   #11
68Timber
I know the pieces fit
68Timber's Avatar
Usually folk bolt the crossmember to transmission and drill holes in the frame to bolt it in its new spot. Make sure the dist cap is good for clearance and it shouldn't matter. How much trouble was it installing the linkage and pedals? Love the vintage valve covers btw.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 11-20-2012, 06:02 PM   #12
thesickc10
Hey would you mind measuring how far back from the firewall you made that hole for the shifter? im doing the same thing right now but with a supert10. How you going mechanical or hydraulic clutch?
1985 c10 355 th350 (working on 4 speed conversion to super t10)
1979 camaro 358 super t10
2003 f250 superchip slp exhaust
thesickc10 is offline   Reply With Quote
Old 11-20-2012, 06:41 PM   #13
ECU PIRATE
ECU PIRATE's Avatar
I love that old stuff!! The newest thing on that motor are a few gaskets and the Hays clutch parts. The flywheel and tranny are vintage 1968, while the motor is an 81' 4 bolt main. I haven' t swapped the pedals or column out yet but, everything is in my garage. I will end up moving the crossmember forward the required amount or replacing it entirely.
The Fleet........
Old 11-20-2012, 06:49 PM   #14
ECU PIRATE
ECU PIRATE's Avatar
I could give you dimensions but your set up maybe different. Easier thing to do would be laying some tape down the center of the tunnel centered on the hole in your crossmember. Verify this with he center of your tranny and tranny mount. My shifter had about a 2 1/4" offset from the center point. I cut my floor 4 times and still need to trim it a little more to clear in 2nd and 4th gears. I can get some measurements for you on Thursday before I head to my folks for dinner. I am going to measure it for you from inside of the cab. Your cut out will nearly be all he way back where he hump starts to rise and about 1" from where it starts to dip to the driver's side floor. You should be alright if you can cut something about 2 1/2" to 3" square. Maybe swb85 will chime in. He has been my go to guy on this swap
The Fleet........
Old 11-20-2012, 08:45 PM   #15
thesickc10
cool thanks man.
Old 11-22-2012, 08:53 AM   #16
ECU PIRATE
ECU PIRATE's Avatar
Here you go bro. I will be heading back to Easton, Pa in about a month for X-Mas
The Fleet........
Old 11-22-2012, 08:54 AM   #17
ECU PIRATE
ECU PIRATE's Avatar
The Fleet........
Old 11-22-2012, 08:55 AM   #18
ECU PIRATE
ECU PIRATE's Avatar
Happy Thanksgiving to all..............
The Fleet........
Old 11-22-2012, 10:06 AM   #19
thesickc10
awesome thanks man! Easton is only about 45 minutes from me. Are you bringing your chevy for the holidays?
Old 11-22-2012, 10:23 AM   #20
ECU PIRATE
ECU PIRATE's Avatar
Nice......the ole girl is in the garage for another winter I am sad to say. 45 minutes ain't that bad. I normally make parts run every time I am up there. Drop me an email bro: ecupirate98@cox.net
Mike
The Fleet........
