Old 11-17-2012, 08:38 PM   #1
lynx5653
lynx5653's Avatar
dash extender
I have seen many trucks with lower dash extensions are these custom built or can they be purchased somewhere? I have a 59 apache and would like one if they are available.
Thanks for any help
1955 2nd on 86 chassis
Daily driver
lynx5653 is offline   Reply With Quote
Old 11-17-2012, 09:35 PM   #2
mr48chev
mr48chev's Avatar
Re: dash extender
A photo of what you are looking for might help guys come with something. Years ago I saved a piece that goes under the dash of an early 70's Ford Maverick that has a couple of cubbie holes to stick stuff in. It's still out in the shed somewhere where it's been for 25 years. I don't know of much in the aftermarket but you might look under the dashes of cars and trucks out of the early 70's to see if there is a panel that can be removed and modified. International travelalls (sp?) come to mind for some reason.
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 11-17-2012, 11:36 PM   #3
youngrodder
youngrodder's Avatar
Re: dash extender
Lynx5653
I had my lower dash panel made out of steel. I also reshaped the bottom of then dash so it goes straight across.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 11-17-2012, 11:38 PM   #4
torchlight
torchlight's Avatar
Re: dash extender
I've often heard these called a "valance" and all I've seen are custom made.
torchlight is offline   Reply With Quote
Old 11-18-2012, 12:01 AM   #5
youngrodder
Re: dash extender
I have also seen some made out of paneling and such that you would use for upholstery. Then they cover them in the same material as the rest of the interior.
Marc
Old 11-18-2012, 12:23 PM   #6
Dan in Pasadena
Dan in Pasadena's Avatar
Re: dash extender
Originally Posted by youngrodder View Post
....I also reshaped the bottom of then dash so it goes straight across.
Marc
Marc, Any more info on this "reshaping"? Any photos?
Dan in Pasadena is offline   Reply With Quote
Old 11-18-2012, 07:02 PM   #7
_Ogre
_Ogre's Avatar
Re: dash extender
mine is home made out of fiberglass
the base is cardboard mailing tube and plywood held together with hot glue gun and staples
shop air compressor timer
Old 11-19-2012, 08:50 AM   #8
lynx5653
lynx5653's Avatar
Re: dash extender
that looks really nice, wish I knew how to do fiberglass work. I really like the cover for steering column. Might try youngrodder's aproach and use a piece of metal, his look nice also.
Thanks for pics
Daily driver
Old 11-19-2012, 10:06 AM   #9
54 jimmy
54 jimmy's Avatar
Re: dash extender
here is pics of my lower dash extensions.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 11-19-2012, 10:43 AM   #10
youngrodder
Re: dash extender
Dan-
Here are a few pics that show my dash better.
[IMG][/IMG]
[IMG][/IMG]
Basically I cut the bottom of the dash off that dips down (where the ignition switch and other stuff where located). Then I welded in new metal to fill the void. This just allows for a straight across piece of metal for the lower panel. I have seen it also done where the dash is left in tack and the lower dash panel is contoured to fit around the factory dash where it dips down.
Make sense?
Marc
Old 11-19-2012, 12:38 PM   #11
Dan in Pasadena
Re: dash extender
Perfect sense. Thanks!
Do you own a sheet metal brake? Us that how you made you extender/valance? Have it don't by others, or maybe weld up from flat sheet?
Old 11-19-2012, 01:14 PM   #12
youngrodder
Re: dash extender
It was made by a friend of mine with a break. You could make it by any of the ways you mentioned. You could also make it out of board/paneling and upholster.
Marc
Old 11-19-2012, 07:08 PM   #13
Dan in Pasadena
Re: dash extender
Thanks Marc,
I notice therre is no link to a build thread in your signature so I did a search on your name for threads you'd started. I found plenty but none of them are really a "build thread".
I like your truck so much I wondered how a "young rodder" could build something so nice? Then I saw you'd mentioned its been an 11 year build so I'm wondering if your last name is "Young" or if you WERE young when you started the build? Maybe 12 years old?!! ha ha. I am curious just how good/bad condition your truck was in when you began because she's nice as can be now. HUGE congrats on such a nice ride. - Dan
Old 11-19-2012, 07:26 PM   #14
BlueJeep
BlueJeep's Avatar
Re: dash extender
Dan-
Make sense?
Marc
Did you re-build the structure that is at the bottom of the dash too or just fill the void? Wondering about doing this to mine, but not sure how much work I'm willing to do on it.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 11-19-2012, 10:47 PM   #15
youngrodder
Re: dash extender
Thanks Marc,
Dan-
Good detective work...No build thread. Yes I was much "younger" when I started the project. I was in my late 20's and most of people my age were not into street rods so that is what gave me the idea for the name. The truck was a driver when I bought it but looking back I didn't use/keep much of the original truck. This project was started prior to being married and prior to my (2) boys being born. For these two reasons the truck budget took a hit. I also did myself no favors going with air ride and a fuel injected engine to name a few.
All that is left is to finish the interior which I will be working on now until spring. Any other questions, give me a shout.
Thanks for the kind words.
Marc
Old 11-19-2012, 10:54 PM   #16
youngrodder
Re: dash extender
I really didn't restructure the dash much as I didn't see a need for it. Keep in mind that the dash will also gain some support from the lower valance if you make it out of metal (which mine is).
Marc
Old 11-19-2012, 11:02 PM   #17
kpdalton
Re: dash extender
The ones I've seen are the vintage air kits that are premade for 47-53 trucks. Or later if you have the later model. People will paint them to match the dash.
kpdalton is offline   Reply With Quote
Old 11-19-2012, 11:06 PM   #18
BlueJeep
BlueJeep's Avatar
Re: dash extender
That's what I have now and it just looks...well....plastic.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 11-19-2012, 11:13 PM   #19
kpdalton
Re: dash extender
You could always do like mine, rip out the dash and start over making it long and clean.
Old 11-20-2012, 06:30 PM   #20
_Ogre
_Ogre's Avatar
Re: dash extender
Thanks for pics
my interior was my first fg build
check out the interior build link in my signature
easy peasy
Old 11-20-2012, 06:38 PM   #21
mr48chev
mr48chev's Avatar
Re: dash extender
That's pretty slick KPdalton. It's one way to fix a hacked up dash were someone chopped it up to put a head unit in at some time or other damage that dashes seem to get in the name of modifying.
I had exhaust tubing bent to make a new dash for the 48 back in the 80's but it didn't turn out the way I had hoped. Several guys took the idea and ran with it and turned out some really nice dashes over the years though.
I've saved a dash out of a car I used to have that will get modified to put in the 48 now. I replaced that dash with a near perfect one out of a parts car and saved the old one.
