Old 11-18-2012, 12:11 AM   #1
WIDESIDE72
WIDESIDE72's Avatar
72 Big Block swap parts almost everything you need to install a BBC
I started accumulating parts to swap a big block into my 71 GMC but sold the truck, and now I need funds to put the big block into a 79 Malibu instead. Most of the parts came from here on the board.
Shipping to lower 48 is included in prices
Here is what I have:
72 (only) big block alternator brackets, 3 pcs and most if not all hardware SOLD
72 (only) engine mount frame brackets, biscuits and clamshells along with frame bolts and motor mount bolts SOLD
Newer 4 row brass and copper radiator, holds water, came from a running truck $150
Original 4 row brass and copper 4 row holds water, came from a running truck as well, is noticeably heavier than previous radiator. There is one tube that is bent but not leaking. SOLD
4 row radiator hold downs and bottom mounts [B]SOLD
Big block 4 row fan shroud no cracks or breaks SOLD
Pair of lower fan shroud retaining clips SOLD
Big block power steering pump, brackets, pressure and return lines, remote resevoir with cap and hose SOLD
7 blade big block AC clutch fan $50
Oil pressure gauge line with correct adapter to screw into block SOLD
Power brake booster steel vacuum line and hose. SOLD
3 pc pulley set for truck with AC. The lower pulleys are two peices for a total of 3 grooves. The upper pulley has two grooves. SOLD
72 V8 throttle cable, return spring and mounting bracket $30
V8 wiring harnesses. I was told this was off of a big block truck but have not verified. One has only one wire cut (yellow) $50
V8 wiring harnesses. I was told this was off of a big block truck but have not verified. Has a few wires cut and the tape has been unwrapped $30
New in box rebuilt and primed big block short water pump to work with above mentioned pulleys and brackets SOLD
I do not have the A/C brackets as the truck this was going to go in did not have factory A/C and I planned to install aftermarket A/C if I got that far. I also do not have the heavier front coil springs required for a big block.
The total for all parts listed separately is $1,375. I will take $1100 for all of it, or $1000 if you only want one radiator (you pick which one)
Prices include shipping to lower 48
Please do not send PM's. Keep the inquiries in the thread.
I want to try and sell this all together to simplify things but if you want to put yourself inline for individual pieces please do so. As soon as it is apparent in the thread that I can part this out, I will do so.
WIDESIDE72 is offline   Reply With Quote
Old 11-18-2012, 12:17 AM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: 72 Big Block swap parts almost everything you need to install a BBC
oem radiator
hold downs
shroud
Old 11-18-2012, 12:29 AM   #3
WIDESIDE72
WIDESIDE72's Avatar
shroud ears close up
power steering pump and brackets
clutch fan
Old 11-18-2012, 12:34 AM   #4
WIDESIDE72
WIDESIDE72's Avatar
even more photos
Old 11-18-2012, 12:41 AM   #5
WIDESIDE72
WIDESIDE72's Avatar
oil pressure line
power brake vacuum line
pulleys
throttle cable
Old 11-18-2012, 12:43 AM   #6
WIDESIDE72
WIDESIDE72's Avatar
wiring harnesses
water pump
lower shroud clips
Old 11-18-2012, 07:55 AM   #7
darkhorse970
darkhorse970's Avatar
I am interested in the following items, would you take $160 for these items?
4 row radiator hold downs and bottom mounts $30
Big block 4 row fan shroud no cracks or breaks $125
Pair of lower fan shroud retaining clips $20
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 11-18-2012, 08:15 AM   #8
no moa
no moa's Avatar
Post pics of Malibu please! Love those old malibu's
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 11-18-2012, 11:14 AM   #9
WIDESIDE72
WIDESIDE72's Avatar
I would like to let this ride as a complete deal for this week if you can wait that long. If it doesn't all sell complete by 11/24 I will let you have those three for $160
Old 11-18-2012, 11:28 AM   #10
WIDESIDE72
WIDESIDE72's Avatar
http://67-72chevytrucks.com/vboard/s...00#post5708800
Old 11-18-2012, 02:33 PM   #11
bronze 72 super
bronze 72 super's Avatar
Would like to be first in line for the following items: Alternator bracket 1972 only,oil pressure line, power brake booster line, oem radiator, 4 row hold down brackets. On the oem radiator does it say "harrison" on the top by the fill hole? Please let me price and shipping to 97050, can you make a package deal on all these items? Thanks Mike
bronze 72 super is offline   Reply With Quote
Old 11-18-2012, 02:53 PM   #12
WIDESIDE72
WIDESIDE72's Avatar
I have someone ahead of you for the upper hold downs. If my math is correct, $300 for the rest is a little of a price break for the rest of the items. I will put you in line if it does not sell all together this week if that is OK with you.
Old 11-18-2012, 02:54 PM   #13
WIDESIDE72
WIDESIDE72's Avatar
I will check but I believe I did see the Harrison tag on the radiator
Old 11-18-2012, 04:47 PM   #14
bronze 72 super
Sounds good. If it does say Harrison on the radiator than I'll take it. If not I"ll have to past only on that item. I'll take everything else I requested. Thanks Mike.
Old 11-20-2012, 03:56 AM   #15
WIDESIDE72
WIDESIDE72's Avatar
The radiator does have "Harrison" stamped into it on the tank
Old 11-21-2012, 12:51 AM   #16
Oldironracing
Oldironracing's Avatar
I'm interested in the 72 only big block stands and clams.
OLDIRONRACING
Oldironracing is offline   Reply With Quote
Old 11-21-2012, 12:59 AM   #17
bronze 72 super
O.K. sounds good. I'll take it, along with the other parts when your ready to sell. Mike.
Old 11-21-2012, 03:52 AM   #18
WIDESIDE72
WIDESIDE72's Avatar
I'll put you in line as mentioned above
Old 11-21-2012, 03:55 AM   #19
WIDESIDE72
WIDESIDE72's Avatar
You're in line
Old 11-21-2012, 09:01 PM   #20
WIDESIDE72
WIDESIDE72's Avatar
Still a lot of pieces not spoken for
Old 11-24-2012, 07:34 PM   #21
WIDESIDE72
WIDESIDE72's Avatar
It looks like this will get split up. PM's sent to everyone in line.
Old 11-26-2012, 01:09 AM   #22
WIDESIDE72
WIDESIDE72's Avatar
72 big block frame mounts and clamshells still available. Oldironracing sent me a pm that he will pass on them.
Old 11-26-2012, 07:48 AM   #23
darkhorse970
Payment sent for these items.
Keith
350/700R4
4/6 drop
1980 Silverado
Original paint
49k Original miles
4/6 drop
Old 11-26-2012, 06:22 PM   #24
WIDESIDE72
WIDESIDE72's Avatar
Payment received pm sent getting it packed up today
Old 11-27-2012, 03:35 PM   #25
WIDESIDE72
WIDESIDE72's Avatar
There are still some good parts available. 72 motor mounts/ clams not yet spoken for.
