Old 11-18-2012, 01:05 AM   #1
BrutonLS1
BrutonLS1's Avatar
Reverse lights help
Hey guys, I've got a 68' GMC 1500, I swapped the TH400 with a 700R4 out of an 89' chevy van. I got everything mounted and my Trans linkage hooked up...then realized..NO REVERSE LIGHTS!! One of those Homer Simpson moments, "DOHH!!!". Where's the Neutral Safety switch located? What do I need to do in order for them to work?
-The truck is missing the gear/needle indicator on the column, so I can only look at the hole and count the gears as I move the column shifter.
Thanks in advance
-Bruton
1968 GMC long bed 5.7/700R4
--I'd rather push a Chevy, than drive a Ford.--
BrutonLS1 is offline   Reply With Quote
Old 11-18-2012, 01:38 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Reverse lights help
The NSS is located on the top of the steering column down by the brake pedal.
It has 4 terminals on it, two for the starter and two for the reverse lights. The reverse lights are green.
Name:  horn relay.jpg
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-19-2012, 01:08 AM   #3
BrutonLS1
BrutonLS1's Avatar
Thanks for the picture, helped a lot. Which wire on the starter acts as the ignition wire? The engine is a 2004 5.3l. The starter has only 2 usable posts, compared to the old starter which had 3.
The old wiring diagram shows a purple NSS wire, and an orange and purple wire which is not labeled. Should I put both wires on the same post?
-Bruton
