11-18-2012, 09:45 AM | #1 |
Brighter reverse lights?
Hello guys, I have a 72 pickup and was wondering if there was anyway to make my reverse lights brighter?
I know I can! I know i can! 72 K20 Restoration |
11-18-2012, 10:04 AM | #2 |
Re: Brighter reverse lights?
You can a LED. bulb for the reverse lights.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
11-18-2012, 10:09 AM | #3 |
the boat guy
Wire in some fog lights under the rear bumper. On a switch (helps with tailgaters at nite) or just wire into reverse lights.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
11-18-2012, 10:53 AM | #4 |
paint inside the housings silver or have them nickel or chrome plated
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
11-18-2012, 03:09 PM | #5 | |
Also: http://www.customclassic.com/products/lights/67-72.htm Have purchased, but not used yet, so I can't comment on brightness, or quality.
......its not what your askin', its what your gettin'.... .......every time I screw up, I learn something. Needless to say, I'm learning all the time............ |
11-18-2012, 04:16 PM | #6 |
Run an extra ground wire...I actually ran two of them and it made them a LOT brighter.
71 K20 64 GMC mud truck |
11-18-2012, 04:36 PM | #7 |
About 12 years ago I bought some fog light bulbs that had the same base as a 1156 bulb that I installed in a s 10 and it looked like headlights when backing up I will see if I can find manufacturer and bulb number I think they were made by blazer lighting
Fuzzy |
11-18-2012, 06:55 PM | #8 |
I have done the chrome paint and foil backed tape in the reverse housing.
Filament bulbs will loose their brightness over time, i think they are around 460 lumens new. Keep in mind though that the 460 lumens is not focused or directed. This is why the chroming or reflective tape helps. I have just recently tackled this issue with LEDs, but it was not cheap. I fabricated some LED panels with 60 bright LED's totaling over 350 lumens each side, directing the light straight back. These are blinding and might not be considered legal in some states. i can post pics of how i did it if anyone wants. Last edited by dznucks; 11-18-2012 at 07:04 PM. |
11-18-2012, 07:11 PM | #9 |
Old member
This is the bulbs I used.
http://www.pplmotorhomes.com/parts/r...k-up-bulbs.htm dznucks, I would like to see what you did on your LEDs please.
11-18-2012, 07:21 PM | #10 |
ok. i'll post pics tomorrow.
11-18-2012, 09:31 PM | #11 |
I think I read somewhere that white paint is better for the housing than silver
11-18-2012, 09:49 PM | #12 |
This LED license plate frame looks interesting, but based on the reviews might have some durability issues. Looks like some of the buyers have had to seal the frame during install and coat with UV protection, but might be worth a try.
http://www.v-leds.com/LPF-Reverse-Li...viewsTabAnchor
'68CUSTOM |
11-18-2012, 09:50 PM | #13 |
The original 1156 bulbs are rated at 32 candle power. This is the same luminosity as the stock brake lights with 4 CP for the running light filaments. The 1157 bulb has 32/4 CP, with dual base contacts.
I can never get a straight answer about converting candlepower to lumens.
11-18-2012, 09:54 PM | #14 | |
I would greatly appreciate it if you could find some more info. |
11-18-2012, 10:21 PM | #15 |
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
11-20-2012, 08:44 AM | #16 |
Thank You very much. I just ordered the halogens. I will let you know how they work.
11-20-2012, 08:47 AM | #17 |
Thanks, I ran grounds for the brake lights but did not think about running one for the reverse lights.
11-20-2012, 08:50 AM | #18 |
I purchased the halogens, and if they are not bright enough I will go with the leds.
11-20-2012, 10:43 AM | #19 |
Here's the ones I'm gonna get http://www.customclassic.com/products/lights/67-72.htm
68 c-10 lwb |
