Old 06-03-2003, 01:46 AM   #1
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
traction bars question
What kind/type of traction bars do i need to put on my 70 C20? Can i just go to the local AutoZone and get the ones they have there? thanks
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 06-03-2003, 09:59 AM   #2
crazy longhorn
Fabricate till you "puke"
http://store.summitracing.com/partde...2D21715&view=4 this set is designed for full sized trucks. I have a flipped rear axle, & used a universal set for a car. They are a little short of the spring eye, but otherwise fit/work ok. If your axle is in stock location, & you just removed a couple leafs, you will need the set in the Summit link(for the extra lenght on the mount brackets). good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-08-2003, 08:45 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
If you have leaf springs checkout my traction bars.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 06-09-2003, 11:59 AM   #4
1FaastC10
1FaastC10's Avatar
IMO, you should NEVER use a set of "universal fit" traction bars. the only time they are ok to use is if they are long enough to contact teh spring eye like they're supposed to. if they're anywhere but at the spring eye, it creates a stress point in the spring that shouldnt be there. i have seen quite a few sets of cracked leaf springs, due to traction bars that were too short.
1FaastC10 is offline   Reply With Quote
Old 06-09-2003, 01:25 PM   #5
crazy longhorn
yes, the slapper bar should contact the eye of the spring(thats the proper way). With that said, I have had those slappers "planted" very hard, with warmed up 461" Olds(500ft lbs tork).....the snubbers are a little short of the eyes, but They havent broken those stiff old longhorn springs On a car, I would be a little leary tho......crazyL
