11-18-2012, 08:00 PM | #1 |
Carb recomendations
Hey guys I just built a new motor for my 84 K10 and would like your input on a carb to buy. It is a 383 with RHS cylinder heads,around 9to1 compression ratio, Comp cams XR276 Hydraulic Roller, all comp cams roller rockers, lifters,and push rods. Edelbrock AirGap Intake,Hedman Elite Headers with 3 inch collectors,3 inch pipe into Flowmasters. Truck has a sm465 with a 205 tc. I was thinking about a new Holley street hp 750 double pumper but would like everyones opinion.the truck will be driven daily.
11-18-2012, 10:18 PM | #2 |
Re: Carb recomendations
The 750 will do for that. Should be around 400-450hp with that setup with a lope too if that is a roller. Right?
You going to offroad it? Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
11-18-2012, 10:50 PM | #3 |
Yeah its a roller.Probably want offroad it much since it is going to be my daily driver
11-18-2012, 11:25 PM | #4 |
Ok well it should work. I think holley has a 700cfm truck avenger as well wich has spring loaded floats and needles to help meter fuel accurately when bouncing.
11-19-2012, 10:29 AM | #5 |
are you interested in fuel economy? if so, a dp doesn't really fit the bill. for the money you are going to spend, put a little more in the pot and get a sean murphy(smi carbs) built quadrajet. best off road carb, best for economy, best for throttle response. there are a couple of other companies out there that will build to your specs as well. mountain man and cliff ruggles come to mind also.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
