here, just not logged in
Extension Cord Safety Tip
A buddy was telling me the other day, not to use extension cords rolled up. I’ve never heard this. I’ve been using rolled up cords for about 25yrs now and never had a problem but decided to Google it. It seems he was right. Learn something new every day.
http://www.safetyattitude.com/articl...tricalcord.pdf I’ve been using 3 of these for years now. I’m gonna hate to pull all this cord out every time I need it, but I guess better safe than sorry. |
Re: Extension Cord Safety Tip
Yes and no. The truth is that the overheating is LOAD dependant. If you are running a trouble light, coiling will never be a problem. If you are plugging up an air conditioner, freezer, large battery charger at the same time you will have an issure no matter what. Thinking about what you are doing is the key, making all inclusive rules that rarely apply is not.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Thats what i was telling him. Don't over load the cord and no problems. Thats when he said that just having it rolled up while in use would create heat. Even in light duty use. Then he sent me the link i posted.
So what does everybody here think? Its ok to use rolled up cords as long as you dont go over what its rated or Allways unroll the cord before use? I sure dont want to unroll it if i dont have to. Last edited by dragginmetal; 11-19-2012 at 09:34 AM. Reason: added more. |
Any body can find an Internet article about anything they want, good or bad. All those home spun diatribes about friend or a neighbor are nothing more than entertainment. Now if United Laboratories or Consumer Reports published a warning I would be more inclined heed.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Hand Crafted C-10
![]() Join Date: Aug 2006
Great subject and something I would never have considered.
I think it would alright to use a rolled up cord as long as you dont overload it. But, better yet, use the shortest cord you have for what you are doing. I know a few folks that daisy-chain their cords but it seems to me that that would dammage the cord and be a safety issue also.
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
#6 | ||
I have used many drop lights and drop cords that hang from the ceiling and never saw a warning about unloading the whole reel just don't over load the cord that is why they have a rating on them
Fuzzy |
The "not to use extension cords rolled up" thing I heard was due to ya know how ya wind a wire around a nail to make a magnet, the loops of wire still have a field effect, that causes more load then needed. we had to always lay out the cords at the job site.
#9 | |
That was his first point to me. So i said, I thought the insulation was there to help stop that. That's when he started talking about heat build up.
biggest thing is the longer the extension cord the heavier gauge wire it should be made of to carry the load without melting// ALOT of people go for the cheap cheap longer ones and have all sorts of problems burnin things up
#12 | |
the insulation only stop direct contact shorts, cross talk or effects of power generation don't care about some rubber. |
#13 | |
I wonder how drop cords get away with it. Now i'm right back where i started. To unroll or leave rolled? Seems the only thing everyone is sure of is don't over load the cord. |
#14 |
Well our anal retentive boss[who was a mechanical engineer ] would go on and on about the effects and how were burning up his equipment not laying them out straight.
#15 |
That is incorrect. AC cords, extension or otherwise, will never make a magnet. The hot and neutral cancel the induction. You need a single wire for induction.
#16 |
I know a guy who's shed burned to the ground-the FD determined that it was because he (foolishly) ran romex free air from his house. And then put 2 or 3 wraps around the top of a pole, you know, to take the weight. Apperently, that's where the fire started.
I have several extention cords, but the one's I use most are just 10 or 12 foot long. They can be had fairly reasonably if you just buy bulk cord and put your own ends on. Then you can have the lenght you need.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
#17 |
![]() Join Date: Nov 2003
Or just run the 50 footer over with the lawnmower and by the time you get is all unwrapped from the mower the only useable pieces left are a 10' and a 12'.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#18 |
Well that isn’t what I meant, just an example, something about the wire being in a loop causing more resistance, which then put more load on the compressors as the motors didn’t get as much juice as it needed or something, as construction sites have only 1 temp hook up, often by the road and each contractor has to run a mile of cords all from the same source.
#19 | ||
#20 |
Internet myth
#21 |
#22 | |
#23 |
![]() Join Date: Sep 2005
i got a cord thats rooled around an old rim hanging on my shop wall at work and i've never unrolled it and have never had any issuses i use it for work lights and a small battery charger no issuses in 10 years its been there
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#24 | ||
#25 | |
for me id goto Andersons to find wire on a roll like that, been around a while place. on the back wall, big spools of all kinds of wires, cables and chain. |
