Old 11-18-2012, 09:30 PM   #1
RHGuyettejr
RHGuyettejr's Avatar
Cab Question
So I have been looking at the mass of smashed in corners on the back of my cab, and more and more thinking it will never look right, even after hours of body work. So I just wanted to know if a 2wd cab will for sure fit a 4wd cab, I know there is a low and high hump cab, my cab is set up for a sm465 and is a high hump in the center, but this piece could be swapped to the new cab correct? from what I have looked at the cab mounts and everything look to be the same.
Thanks,
Jr
RHGuyettejr is offline   Reply With Quote
Old 11-18-2012, 09:58 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Cab Question
I bet your answer is in this note from another thread about cabs. It tells about using replacement cabs (in the day) for a variety of apps. The cabs will mount the same. The floor hump may not be the same, but you'll be able to see the differences and make the adjustments you need.
Member Nr. 2770
Old 11-19-2012, 12:17 AM   #3
danw210
69 K20
Re: Cab Question
You will have to cut the floor of the 2wd and use the high hump. There are no other differences.
danw210 is offline   Reply With Quote
Old 11-19-2012, 12:35 AM   #4
Shyguy
Junior Member
Shyguy's Avatar
Re: Cab Question
Yes, the low hump can be cut out and use the high hump. Also many two wheel drive cabs had high humps, any with the SM-420 or SM-465 4 speed transmissions have high humps.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 11-25-2012, 12:42 AM   #5
RHGuyettejr
Re: Cab Question
Yes thank you, I got one with a high hump from a 69 GMC 3/4 ton with a 4spd, so i will just have to make a hole for the 4 wheel selector.
Old 11-25-2012, 12:57 AM   #6
c10srule
c10srule's Avatar
Re: Cab Question
how are things going way up there in keene? i lived in walpole from 95 to 2000, bought my truck in mass at the state border. loved driving in the snow, stay warm up there.
c10srule is offline   Reply With Quote
Old 11-25-2012, 10:12 AM   #7
THE BOSS
Re: Cab Question
i have a 72 2WD cab on a 1971 4WD chassis, i just dropped the transfer case mount a little. it changes the engine angle a couple degrees.
mine has a TH350 and a 205 transfer case. 4WD stick in the cab looks good.
i went with a MSD HEI, that puts the cap is close to the firewall, it clears and works fine.
THE BOSS is offline   Reply With Quote
Old 11-25-2012, 05:57 PM   #8
RHGuyettejr
Re: Cab Question
They are pretty good. Rusty as usual haha. Keene and walpole had some major floods in 2005 and just recently. RT 123 got washed out in Alstead and all the houses along it are gone, one person died.
