Old 11-18-2012, 09:32 PM   #1
mattpiotr
What Size Battery Do I Need?
I have a Sears Diehard Battery In The Truck Now And I'd Like to replace it before winter hits. the battery in there now is 700 cca. i installed a snow plow and a few strobe lights on the truck. ive always hear good things about Exide Batterys and my father has always had good luck with them. i went to Menards and found a Exide top and side terminal battery with 770 Cold Cranking Amps at 0 degrees and 950 Cranking Amps at 32 degrees. the price on it is $77.94. i was wonder if that would work for me
mattpiotr is offline   Reply With Quote
Old 11-18-2012, 10:39 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: What Size Battery Do I Need?
If it has the correct terminals yes. I usually just go overkill on my trucks and get the biggest and strongest that can fit in the box
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
