Old 11-18-2012, 09:43 PM   #1
70blackfish
Will this 15 inch rim fit with disc brakes?
I have these 15 x 8 wide rims, I want to know if they will work with disc brakes?
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 11-18-2012, 09:56 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Will this 15 inch rim fit with disc brakes?
I picked up a set of those wheels that I intended to use on my '76 Blazer. But, I sold 'em before I had a chance. Easiest way to find out is to just bolt it up...if that's possible.
I don't think there were any wheels like that until after GM went to discs on the '71's. I had to use some GM wagon-wheel rims from a late Seventies 4WD on the front of my '69, which has discs. I'm guessing they're gonna work.
Member Nr. 2770
Old 11-21-2012, 11:30 AM   #3
70blackfish
Btt
Old 11-21-2012, 11:52 AM   #4
cdowns
cdowns's Avatar
if manufactured after 71 yes pre 71 proally not
Old 11-21-2012, 12:31 PM   #5
Rochlow
Those have the three nubs for the hubcaps, So they appear to be pre-71 and as far as I know won't work with disk breaks (my 15x6 didn't). If you find those wheels with the four nubs for the hubcaps they should work.
Rochlow is offline   Reply With Quote
Old 11-21-2012, 01:28 PM   #6
70blackfish
Is the date a mfr. stamped on them so where?
Old 11-22-2012, 04:23 PM   #7
Duncan and son
I dont think they will fit with disc. See the six raised "nubs" between the lug nut holes... On the 71-72 that erea is smooth.. level
Hope that helps Paul
You can shear a sheep every year, but you can only skin it once
The person dealing with facts is never at the mercy of the person dealing with theory
1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn
1975 Silverado 454 Crew cab camper special dually
Duncan and son is offline   Reply With Quote
