Moderator
![]() Join Date: May 2007
Excellent condition tilt column
Here is a tilt column I pulled from a low mileage van. It is in excellent condition, and complete with all parts. No broken parts, very tight and solid. The shifter is solid, no play whatsoever, and the shift pin needs to be removed with a center punch and installed with a hammer. The detent has no wear and this will NOT slip out of the Park position. This column is not a core for rebuild...it is ready to use. I added the correct truck tilt/turn levers, and the horseshoe wire harness adapter so that it will plug right into a truck. $280 Shipped in the conus. Shipped means packed proprerly in an oversized box, with plenty of bubble wrap to ensure the shift collar does not get bent up in transit (seen this happen more than once).
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Moderator
Re: Excellent condition tilt column
![]() Join Date: Sep 2010
Do you have more picks, close ups, is the hazard switch in good shape? If all looks good I'll take it.
Moderator
Posted via Mobile Device Posted via Mobile Device
Moderator
Moderator
Sorry iPhone flips the pics for some reason
Moderator
Hazard switch is the OEM van style, and functions as it should. Can be unscrewed and the "horn" style substituted.
![]() Join Date: Sep 2006
I can't remember is there anything you have to do but bolt it in. I am interested if thriftmaster does not want it.
I'm interested in the column. You'll have to forgive my ignorance, is this a direct bolt in for a 72 GMC?
Thanks,
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
#11 | ||
Moderator
