Old 11-19-2012, 12:52 AM   #1
dbmx66
how many splines does my 8 lug 10 bolt (8.5) have
gonna get a lock right for it, need to know the spline count, thanks.
dbmx66 is offline   Reply With Quote
Old 11-19-2012, 03:15 AM   #2
Redcap
Re: how many splines does my 8 lug 10 bolt (8.5) have
Pull an axle and count the splines. Going to have to do it anyway.
Redcap is offline   Reply With Quote
Old 11-20-2012, 07:19 AM   #3
What axle do you have? HO52/72s have a 10.125" ring gear.
Old 11-20-2012, 08:02 AM   #4
dbmx66
its an 8 lug 10 bolt front. its an 8.5 ring gear, it came out of the same truck the had that my 14bff.
Old 11-21-2012, 07:21 AM   #5
Oh,ok. For some reason I automatically assumed rear...my bad. I'm not sure but I believe they all are the same spline count. No changes that I know of. But,I've never taken one apart and can't answer how many splines. Did you talk to whoever you want to buy from? They could confirm if they are all the same or not. I'm assuming you don't want to tear into it until you have everything you need.
Old 11-22-2012, 03:12 AM   #6
blasher
blasher's Avatar
I've got a 6 lug 10 bolt GM front and it has 28 splines. Not sure if this helps.
blasher is offline   Reply With Quote
Old 11-22-2012, 07:10 AM   #7
MTCK
MTCK's Avatar
28 or 30 depending on pre or post 1989. Smart $ is pull and check as stated above.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 11-23-2012, 01:28 AM   #8
Mr. 250r
Mr. 250r's Avatar
Could also have i think 32 splines but i think that was in the early 90s ones i think mine has that i never did check it after swapping in a d60
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 11-25-2012, 12:06 PM   #9
dbmx66
well im just getting everything i need together, cuz im putting one tons in. so ill just have to pull a shaft, im stilling waiting on some 40s on a 16.5 rim to come around anyway .the lockers only come in 28 or 30 spline, idk lol
