Old 11-19-2012, 12:56 AM   #1
hotrodtim
1951 Door hinge question
I'm not sure what these are called but they cover the opening on the cab that the hinge fits into. They were spot-welded onto the hinge but I removed them to straighten or replace them. Three of the four are useable but as you can see, one is badly rusted. Does anyone make a reproduction piece that anyone knows of? All the extra holes are from my spot-weld cutter.
hotrodtim is offline   Reply With Quote
Old 11-19-2012, 10:05 AM   #2
f18delta
Re: 1951 Door hinge question
Might be cheaper to buy some flat steele and cut your own out. Just get it as close to the right thickness as possible and trace your outline.
1952 Chevy 3600 - Sancha
f18delta is offline   Reply With Quote
Old 11-19-2012, 11:00 AM   #3
mknittle
mknittle's Avatar
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 11-19-2012, 07:40 PM   #4
Daze57
Daze57's Avatar
x 3 ^
Daze57 is offline   Reply With Quote
Old 11-19-2012, 10:23 PM   #5
hotrodtim
I considered that but was hoping not to have to. As many of these trucks are out there and as beat up as these get I thought surely someone would be making and selling them.
Old 11-20-2012, 10:01 AM   #6
mknittle
mknittle's Avatar
They are made but you have to buy the hinge to get them.about $50.00.
Mark
My GMC build.
Old 11-20-2012, 10:01 PM   #7
hotrodtim
$150 a set for hinges is about the cheapest I've seen and refurbishing them is pretty inexpensive. I'll fab something up that will work, it's not a show truck.
Old 11-21-2012, 11:18 AM   #8
Gabbyp
I have the same problem of rusted hinge plates. Over at Stovebolt.com in their tech tips there is a detailed way to fabricate the plates. Looks easy to do.
http://www.stovebolt.com/techtips/do...nge_plate.html
Gabbyp is offline   Reply With Quote
Old 11-22-2012, 12:07 AM   #9
hotrodtim
Thanks, I'll check it out.
Old 01-27-2018, 11:01 PM   #10
Scott2
I know this is old but I ran across it in another search and have good info. I found Dr. J’s Restoration Rex via Flysocal and just got my hinges rebuilt. Not cheap but they turned out great and there should be no fit issues.
He also offers new faceplates which I took advantage of: http://drjsrestorationrx.com/wp-cont...5223578299.jpg
Website is: http://drjsrestorationrx.com
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
