Old 11-19-2012, 07:47 AM   #1
melhilburn
melhilburn's Avatar
Replace Cab / frame mounting hardware
is there a way to replace cab / frame bushings one by one without having to remove the body??
melhilburn is offline   Reply With Quote
Old 11-19-2012, 08:27 AM   #2
bk2life
Re: Replace Cab / frame mounting hardware
yeah, floor jack, piece of wood under the rocker. take out body bolts, jack up, replace bushings, let jack down repeat other side.
bk2life is offline   Reply With Quote
Old 11-19-2012, 09:57 AM   #3
melhilburn
melhilburn's Avatar
is the rocker the farme rail?
Old 11-19-2012, 09:53 PM   #4
FF SIX ONE
FF SIX ONE's Avatar
Its the part of the cab under the bottom of the door.
FF SIX ONE is offline   Reply With Quote
Old 11-19-2012, 11:10 PM   #5
jdl71
jdl71's Avatar
I'm not sure about one by one, but one side at a time is how it's usually done.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 11-20-2012, 05:57 AM   #6
melhilburn
melhilburn's Avatar
Is it worth the effort to replace the bushings - I'm thinking about replacing them just because they are old - Is there any real benefit to replacing them??
Old 11-20-2012, 06:47 AM   #7
tincan1966
tincan1966's Avatar
One of the main benefits of replacing them is if you're doing body work, all the sheet metal can be aligned properly. Also it can get rid of squeaks, rattles, etc.
I remove the bolts on the side I'm replacing, and loosen the other side(don't forget to do the same with the radiator support bolts, too) If your rockers are rusted, there is a floor support brace that runs front to back, between the mounts, just outside of the frame rail. Use a block of wood betwen jack and brace and lift cab enough to remove mounts.
tincan1966 is offline   Reply With Quote
