Old 11-19-2012, 12:30 PM   #1
Cracksrubi
Cracksrubi's Avatar
Anybody running paddle shifter
So m carb motor decided to eat some pistons and rods so I've started looking into a 6.2l/6l90e swap not gonna lie the video of v502s truck doing some doughnuts really concreted the choice enough rambling back to my question
Tci makes a kit for this tranny 6l90e and. Wanted to see if any body already has any experiance with this kit or others. Also any pics, advice or personal experiences appretiated.
68 c-10 lwb
Cracksrubi is offline   Reply With Quote
Old 11-19-2012, 03:57 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Anybody running paddle shifter
In. I've been wondering about the paddle shifters too. Where are you getting your 6.2?
Hart_Rod is offline   Reply With Quote
Old 11-19-2012, 04:23 PM   #3
Wasted Income
Boosted Member
Wasted Income's Avatar
I'll be running a tap shift setup with my 4L80E and Megasquirt "megashift" module.
Planning to run this shifter and use the buttons for tap shifting.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 11-19-2012, 05:10 PM   #4
Cracksrubi
Cracksrubi's Avatar
Haven't found a good scource yet but I'm still in the parts collecting stage I'm open to any suggestions about vendors or setup. I'm thinking something like an art Carr or something simple and small in the floor or between the seat custom seat of course. Then ididit or flaming river brushed column with tci paddle shift with display and the no key setup from flaming river also all I need now is to either win the lotto or get this raise I've been promised
68 c-10 lwb
Old 11-22-2012, 02:19 AM   #5
mcmlxix
Collector of Projects
mcmlxix's Avatar
http://twistmachine.com/Paddle_Shifters.html
Rich
1972 K5 Blazer CST Click HERE
Old 11-22-2012, 05:22 PM   #6
Cracksrubi
Cracksrubi's Avatar
That is one sweet setup any pics of how you select PRND there was something I didn't like about there's I think it was no gear indicator but I like the look of those handles better
68 c-10 lwb
Last edited by Cracksrubi; 11-22-2012 at 05:32 PM. Reason: My phone was acting retarded
Old 11-22-2012, 06:52 PM   #7
Hart_Rod
Hart_Rod's Avatar
Dakota Digital sells a nice gear indicator setup.
Old 11-23-2012, 03:05 AM   #8
mcmlxix
mcmlxix's Avatar
You still need a mechanical gear shifter to get from Park to Drive and Reverse. (Floor shifter?) I believe the Dakota Digital gear indicator is indexed off the transmission shifter arm, so it will only show the gear you manually/physically put the trans into.... not the gear you select while using the paddle shifter.
The ECM/PCM should have the data from the trans to know what gear it's in at any given time. The problem is not all readers/controllers have a way to "export" that data to an indicator for the dash...
Rich
