Pinch seam. Do we need it?
That big ugly pinch seam under our cabs and fender do we need it? Kinda disrupts the flow of the body I want to eventually cut it off. Can I do this and weld the seams granted I keep the drainage grooves. Any body have pictures of this?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Re: Pinch seam. Do we need it?
If u are tacking about the one for the rocker then yes u can cut it off and weld the in and outer together if u want. Like y said tho keve the drain there
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
then your frame and gas tanks will be showing more. time the trim the bottom of the frame and put a tank in the back
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
