Old 11-19-2012, 04:25 PM   #1
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Roof drip rail question
The roof of my truck has been repaired on the front corners in the past and some rust is popping out again..
Did the drip rails ever have drain holes in them? Mine are always holding water.
Thanks for your help!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 11-19-2012, 04:59 PM   #2
Anthony Fremont
Anthony Fremont's Avatar
Re: Roof drip rail question
My '66 GMC has four in the drip rail that I found and unplugged. Two in the front sides drip into little rain gutters in front of the vent windows. The ones in the rear sides drip behind the door. They're not drilled holes, they're more like piercings or cuts. I'll get some pictures of them and put them up.
I fixed my drip holes, now water only stands in the big dent right on the "step" in the roof. Thanks to the magnificent double walled GMC cab, I'll have to pay somebody with a stud puller (or buy one) to take it out. For $49 more, GMC made some things allot harder to cope with in the long run.
'66 GMC Custom Fenderside LWB
'90 IROC - L98
'97 1200C Sportster
Anthony Fremont is offline   Reply With Quote
Old 11-19-2012, 05:41 PM   #3
Turkey
Turkey's Avatar
I used a wire wheel and cleaned up the drip rail to find my weep holes. AF is right, they are more like stamped cuts than holes. My rails were filled with caulk I think.
Turkey is offline   Reply With Quote
Old 11-19-2012, 06:20 PM   #4
61_FL_Apache
Who Me?
Does anyone have pics of where they are supposed to be?
Steve
2001 Blazer 4D 2WD
Old 11-19-2012, 06:40 PM   #5
Leadfoot Lambert
Leadfoot Lambert's Avatar
See where it looks like the drip rail is bent out, that's where the piercing is.
Those are the front ones, finger points at there location
Rears are here
65 Chevy short fleet 350 5 speed, soon to be LSX powered
65 F100 short fleet
91 Heritage softail
94 Fatboy
11 Softail Deluxe [wife's bike]
13 Streetglide
http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz
Leadfoot Lambert is offline   Reply With Quote
Old 11-19-2012, 06:57 PM   #6
Anthony Fremont
Here's the front drip rail drain hole:
Here's the back one:
I'm not responsible for that caulk in the windshield seal. I am responsible for this:
and this: (the light spots are the sun)
So you can clearly see that the top 1" of my truck is in pretty good shape.
'90 IROC - L98
'97 1200C Sportster
Old 11-19-2012, 08:49 PM   #7
61_FL_Apache
Who Me?
Thanks for the pics!! All of mine have been filled at some point.. I would like to get at least the front ones opened up again.. Thats where the water always sits.
Steve
2001 Blazer 4D 2WD
Old 11-19-2012, 08:53 PM   #8
61_FL_Apache
Who Me?
I just went and looked at my truck and the little bump isnt even there.. Someone must have tapped it in and sealed it up...
Is it possible some years didnt not have them?
Steve
2001 Blazer 4D 2WD
Old 11-19-2012, 09:46 PM   #9
rcbildr
rcbildr's Avatar
I don't remember seeing them on the front of my 60 either, I'm wondering if that was added when they changed the A pillar for the 64 and up trucks. I just coated the inside of the gutter as best as I could with seam sealer and I've seen where anther member just filled the entire gutter with seam sealer. I'm going to go back and do the same to mine as soon as I can.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 11-20-2012, 01:32 AM   #10
markeb01
Senior Enthusiast
markeb01's Avatar
My 1960 GMC never had drain holes. I've always assumed these were added with the new cab in 64. That's why I just filled mine up with seam sealer so the water would have no place to collect.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 12-09-2017, 08:34 AM   #11
G8rN@te61
can somebody repost pictures of the drain holes? I just spent a whole day yesterday repairing rusted metal in my cab. I noticed that small rivulets of water are coming down inside back corners which have caused major water damage to the back left and right of the cab corners. Also at front door pillars where it starts to slope up. I am assuming seam sealer is gone....
G8rN@te61 is offline   Reply With Quote
Old 12-09-2017, 10:23 PM   #12
urmyboyblue
Sorry I don't have pictures. I cut my drip rail out at the divets (side only, there is still a bottom to the rail) so that there are drains at those locations that can't be filled in. Little to no water stands in the drip rail now.
urmyboyblue is offline   Reply With Quote
